targamontess
- Joined
- Mar 1, 2015
- Messages
- 3
I use a light for work to look at welds, mechanical components, in dimly lit environments on average for 3 to 4 hours a week could be up to 40 hours a week use depends.. i cannot use an led light It must be incandescent. For home use i use a light to check on my farm animals in the night as we have coyotes and predators, i also do mechanic work as a hobby and use a light For camping. I currrently use *link removed
online
2) Budget: An easy question, but you may change your mind after answering the rest!
____Up to $40
____I want a flashlight (hand held/self contained).
_
4) Size:
____SMALL - Every day carry (4-7 inches).
____MEDIUM - Holster/belt ring carry. (>7 inches)
5) EmItter
6) Manufacturer:
____I want to buy a light from a large/traditional manufacturer that is r
____I intend to use "Primary"/Disposable Alkaline batteries based on the usual AAA/AA/C/D sized cells common to most stores.
___
____I intend to use Rechargeable cells (NiMH or NiCD) based on the usual AAA/AA/C/D sized cells common to most stores.
____I want to navigate a dark room or read a map (1-10 lumens).
____I want an indoor "blackout" light (15-50 lumens)
____I want to confidently walk around an unlit/unpaved rural area (60-150 lumens).
____SPECIAL NOTE: Burst/Turbo mode Category - There are several lights that will run at a super bright maximum for a very limited period (usually 5-10 minutes) and then will "step-down" to a lower level for thermal control. Check here if this is acceptable.
9) Flood vs Throw: Flood covers an area, Throw reaches out to a distancEs
2 inches to 20 feet i look at all distances
____Less than 1 yard/meter (reading, other close work)
____Less than 5 yards/meters (looking for something inside a dark shed/garage/basement)
____5-20 yards/meters (check out a noise in the backyard)
____50-150 yards/meters (I live in a very rural area/farm with wide open space
need at minimum 2 hrs
I dont want it to break but my 2 d energizer hasnt broken in 5 plus years
____i need a simple switch where i can hand the light to someone and they wont ask me questions about how to use it.
Simple
14)Material/Finish/Coating
Cannot have knurling must be smooth
15) Water resistance
____Get rained on any night it rains and i need to close up coop outbuildings.
16) Storage conditions
____usually keep it near me in car or house bring to work and back home
_
Would like the bulb to last a long time and be easy to get
online
____Up to $40
_
4) Size:
5) EmItter
6) Manufacturer:
___
Simple
_
