HKJ
[size=+3]Samsung ICR18650-22F 2200mAh (Green)[/size]
Official specifications:
The datasheet for this cell says 2008, i.e. it is a old design, this can also be seen on the limited capacity and current capabilities.
The discharge curves looks good enough, good tracking between the cell when not overloaded.
[size=+3]Conclusion[/size]
Not the most interesting battery today, but the cell is good enough within its limited capabilities and it can easily surpass some cheap brands.
[size=+3]Notes and links[/size]
How is the test done and how to read the charts
How is a protected LiIon battery constructed
More about button top and flat top batteries
Compare to 18650 and other batteries
- Nominal Capacity: 2200mAh
- Charging Voltage: 4.2V ±0.05 V
- Nominal Voltage: 3.6V
- Charging Method: CC-CV (constant voltage with limited current)
- Charging Current: Standard charge: 1100mA, Rapid charge : 2200mA
- Charging Time: Standard charge: 3hours, Rapid charge: 2.5hours
- Max. Charge Current: 2200mA
- Max. Discharge Current: 4400mA
- Discharge Cut-off Voltage: 2.75V
- Cycle life: 300 cycles to 68%
- Cell Weight: 44.5g max
- Cell Dimension: Diameter(max.):18.4mm, Height: 65mm max
- Operating Temperature: Charge : 0 to 45°C, Discharge: -20 to 60°C
- Storage Temperature 1 year: -20~25°C, 3 months : -20~45°C, 1 month : -20~60°C
