Hi all,
This is something some of you may not have considered, I didn't until just now.
We all know that while we are charging lithium batteries, we should attend to our chargers and cells - making sure that the batteries are not overheating, there are no fumes and being sure to remove the cells in a timely manner once charging finishes. That's just common sense.
While typing out another post here on CPF we just had a small earthquake here and it got me thinking. If you have a charger loaded with high capacity 18650 cells and a large earthquake hits it is very likely to fall off the desk/table, smash on the floor and scatter cells everywhere. These cells may even be damaged on impact and will roll around - perhaps ending up in places where they are hard to reach in a hurry like behind a TV cabinet or bookshelf. Imagine damaged cells that may now be at risk of shorting out rolling behind your TV cabinet, and starting a fire while you are busy taking cover under a table yourself from the earthquake!
Some of you may think I am being too cautious - I mean, your mobile phone or some other device could also get smashed but I think they are less likely to start a fire as the cells would be fairly well protected inside the device. I wouldn't worry at all about a flashlight with an 18650 cell locked+loaded hitting the floor (other than feeling bad for it getting scuffed).
I was born in England where earthquakes do not happen as a rule (okay, I know they can but it is extremely rare) so it didn't occur to me.
Most fires that occur as a result from earthquakes happen because of broken gas lines, burners/heaters that topple over while switched on and damaged appliances. Lets not have our li-ion charging contributing to this. Don't put your charger right at the very edge of your table if you live somewhere with frequent earthquakes
