I work at night, thusly, I use a flashlight all the time. I have a Nitecore MT2A, which I like very much...except for one thing. Double clicking the base button cycles through the light's various modes. With some regularity, I accidentally switch the light from its medium setting (which I mostly use) to the next setting, SOS. Then I have to cycle back through them to get back to where I want to be. I want another light anyway, and the next one should not present this problem; something similar to the Nitecore, but with a different interface.
Needing a light that meets the following requirements...
It has been suggested that an EagleTac P20A2 MKII meets these requirements. Are there any other lights you would recommend?
- Two AA power source; I've got some Eneloop Pros, and I don't want to mess with other batteries.
- Slim, tube-like profile (Is there a proper term for this? Lightsaber?).
- Variable intensity, up to at least around 300 lumens.
- Activation button on base.
- Activation button only turns on the light; modes are selected through some other means.
