computenik
- Joined
- May 20, 2015
- Messages
- 3
Morning i recently changed the head of my Dive Rite LED500 to a sumpdonkey3 however i have since hit a problem.
During a recent cave dive the battery cannister opened up causing a flood of the unit and the head.
Sump donkey kits for the MR11 head are no longer available, so have had to revert to going to cutter electronics however not getting any replies from them so need to ask a few question here.
Firstly what is the difference between a buck and booster kit? I am guessing it has something to to with voltage levels of the battery but am unsure. as in between the Cutter electronics Cutter XPL-MR11 Kit Boost or Cutter XPL MR11 Kit Buck kits
Secondly as the battery is now Fried looking at replacing it with something more powerful and better duration. Currently has 10 x HR-4/3 FAU batteries in a 4500mah 12V Pack 140mm x 49mm Round pack.
So wish to reply it with a premade pack like this one from Batteries space.
Any Assistance on this would be greatful.
Paul
Datasheets | HR-4-3FAU(4.5AH) |
Product Photos | HR-4/3FAU(4.5AH) |
MSDS Material Safety Datasheet | Nickel Metal Hydride Battery MSDS |
Standard Package
| 300 |
Category | Battery Products |
Family | Batteries Rechargeable (Secondary) |
Series | TWICELL |
Battery Chemistry | Nickel Metal Hydride |
Battery Cell Size | 4/3 FA |
Voltage - Rated | 1.2V |
Capacity | 4.1Ah |
Size / Dimension | 0.71" Dia x 2.66" H (18.0mm x 67.5mm) |
Termination Style | Flat Top (Non-Extending) |
Discharge Rate | 820mA |
Standard Charge Current | 450mA |
Standard Charge Time | 16Hrs |
Weight | 2.19 oz (62.4g) |
Li-ion Battery: 14.8V 5.2Ah (77Wh, 8A rate) for Diving Light | |
Voltage | 14.8V (working) 16.8V ( peak) 11.0V ( cut-off) |
Capacity | 5200 mAh min. (77 wh) |
Protection | 2 x PCB (8A) & 2 x 420 Polyswitch |
Pre-wired |
Max. Discharging Rate | 8 Amp limited by polyswitch |
Dimensions | 1.6"(43mm) H x 1.6"(43mm) W x 5.5 "L(139mm) |
Weight | 404 grams ( 14.3 oz ) |
Paul
