I have several of the cells that are pictured on post #56 of this thread:
http://www.candlepowerforums.com/vb...BatterySpaces-4000mah-26650-cells-Graph/page2
The posters on this thread and I probably hadn't heard of 4.30 V and 4.35V cells at that time, and I read no discussion of the significance of the 3.8V.
Can I safely charge them at a 4.35V setting? If so, does anyone know what capacity increase might be obtained?
My cells have been lightly used and seem fine. They delivered 4200 mAh at 0.35 A drain when new when charged to 4.2V. I'll measure them on a new charger/analyzer I'll soon receive.
Two of my new chargers have 4.35 V charge settings available. This forum says that 4.30 V cells may or may not fall within the tolerance band of a 4.35V charger.
Neither Battery Space nor Nailbender (where I bought my cells) still carry the cells so I'm hesitant to ask them.
[edit: I do find a vape store selling MNKE 4000 mAh 26650 cells that refers to both 3.7V and 3.8V in the listing (not confidence inspiring) and says a 4.2V charger should be used. I think I remember seeing these or similar MNKE cells in the 2010 time frame. http://www.fluidvapes.com/batteries/mnke-26650-imr-battery ]
At the time I do remember assuming that the 3.8V marking was probably intended to emphasize the lesser voltage sag under load with IMR chemistry than ICR.
