Peak Eiger Clip
RByers91
Can anyone confirm that the clip for the peak eiger will fit on the other peak models such as the capitan and the logan? I know the thickness between the eiger and logan is about .5" (which i believe the clip has enough clearance for), but would rather confirm before purchasing. Thanks!
AVService
It fits in keychain bodies only. It's held in place by the keychain lug or a momentary switch if used
I know how it works,I have one on an Eiger but the Eiger is so much smaller in diameter and it was not easy to install it on that one let alone a much thicker Logan.
Does it sort of lever away from sitting flat on a Logan until screwed down and then end up oriented correctly?
If I had thought this I would have gotten more than 1 for sure.
