brightnight
- Joined
- Jun 15, 2015
- Messages
- 4
Looking for battery advice for homemade security camera project. I'm looking to power a video camera (~7.4V) for months at a time while I'm away and even the extended camcorder batteries don't last that long or are way too expensive. Most of the time the camcorder will be off but still draws a small amount of power, but the camera turns on and records when motion is detected. I will be hardwiring Lithium ion batteries in series and parallel to power the camcorder to power it for a long time but need help finding the right batteries. I have plenty of room in my setup so I can use any size batteries, but I need advice on what might be the best batteries to use for the cost.
My best guess is I'll need a total of ~8000-10,000 mAh's so I was going to make a bank of lithium ions. Cost is definitely a factor but I need batteries that will work as advertised and depending on the capacity...probably a lot of them (I'll be powering three different camcorders and need a pack for each one). I was thinking of using two 3.7V batteries connected in parallel with connected to two other batteries in parallel to power the camera (4 18650 batteries per camcorder). I've been considering buying Laptop battery packs on Ebay to take apart as an alternative but that worries me as I won't know what I'll be purchasing and still out $50 when I could've bought good batteries to start.
I don't need to use 18650 batteries but I thought I would be a low cost high capacity way to power my camcorders and considering two 3.7V batteries in series gives me the voltage the camcorder needs. Any advice appreciated! Thanks in Advance
