Hi everyone
i'm trying to realize a 100w led flashlight with a very low budget, just for fun!
What i did for now is fixing one of this led http://ledtronix.trade47.com/files/2014/01/100w-led.jpg
to a cpu heatsink+fan, i added the lens (standard 44mm lens + reflector) and i connected it all to a small voltage booster board,
so i can reach the 32-36 V needed starting from a 12v battery.
Now that's the part where i need some help:
1) Is there something as cheap as a 12V 9AH lead acid battery but better (size, duration, discharge rate...etc) than that?
2) The 44mm lens with the small reflector is quite useless, i'd like to concentrate it a bit at least.
I was wondering if reflector made for a COB led would work;
i found this : http://www.dx.com/p/cob-97mm-square-hole-aluminium-alloy-reflector-for-led-lamp-387951
that seems very good, what do you think would be the result ?
If you have any advice please share them, as you can see i'm everything but expert.
