HKJ
[size=+3]Shockli 18350 700mAh (Cyan)[/size]
Official specifications:
This is a high current 18350 cell.
The curves are fairly good, but they do not track perfectly. The cell can deliver 10A when hard pressed, but definitely not 15A.
[size=+3]Conclusion[/size]
This cell is one of the good performing high current cells, I would have liked a bit less variation between the two cells, but as long as the cell is used stand alone it is not a problem.
[size=+3]Notes and links[/size]
The battery was supplied by shockli.com for review.
How is the test done and how to read the charts
How is a protected LiIon battery constructed
More about button top and flat top batteries
Comparison to other LiIon batteries
- Nominal capacity: 730mAh
- Nominal voltage: 3.7V
- Discharge cut-off voltage: 2.75V
- Standard charge: 4.2V 500mA
- Maximum charge current: 1000mA
- Continuous discharge current: 10A
- Pulse discharge current: 15A
- Initial impedance max.: 35mOhm
- Cycle life: 500cycle to 60%
- Operating temperature: Charging, 0°C ~ 45°C, Discharging, -20°C~60°C
- Storage temperature: -20°c -35°c
- Weight: 21g
