Wow are you going to get some wicked suggestions.Looking for the brightest (throw) flashlight that uses one or multiple 18650 batteries for under $155.
What flashlight is this and where can it be bought?
If it's a little more than $155, that's ok too.
I'm guessing that price is for the light alone?
Also, is it throw or flood you desire or a combination of both?
Ordering light OK?
Guys might need some more details.
Have a great one.
Measure wallet now, then again in six months.☺
Flow.
Just light.
Here are 2 that I found that looked good. Are these two any that you'd recommend?
http://www.batteryjunction.com/nitecore-tm16.html
Nitecore TM16 Tiny Monster Flashlight - with CREE XM-L U2 LED - 4000 Lumens - Uses 4 x 18650 Batteries
And:
http://www.batteryjunction.com/fenix-ld75c-xml2.html
Fenix LD75C LED Flashlight- With CREE XM-L2 U2 LED- 4200 Lumens- Uses 4 x 18650 or 8 x CR123
Those cost more than $155.00
I would look into the Acebeam K60. It has been getting a lot of good reviews.
Cool. I looked at that link and didn't see where you could order one. It said, "submit order inquiry" like you're supposed to apply to order one. Is this a loan? lol? Am I approved?
Not too many places sell Acebeam, but I have bought from HKEquipment.
HEDP,
I'll throw this recommendation to ya.
Olight M3XS UT. They currently retail for 149.99. Totally a throw light and still from what it looks very compact.
250,00 kcd in throw.
theoretically in lumens, but that does not overall account for other factors that enhance distance illumination such as depth of and diameter in width of reflector, orange peel or smooth reflector types. really what separates this newer olight javelot m3xs is that the light emitting diode silicone dome covering itself has been removed for greater throw and center spot beam intensity.
All in all, a strong contender to date straight from the box stock.
Flood.
Just light.
I'm reading reviews about that and seeing that it's very floody. I'm looking for a very bright flashlight like the Thrunite but focused beam, not flood.
These statements (and more generally, throw and peak output) are mutually incompatible. You can get bright lights that have decent throw, sure, but a light designed for throw will always EASILY exceed (at long range) a light designed for high brightness, even if it only has a small fraction of the total output.
As usual, the first question to answer should be "what will you use it for?" Everything else follows from this.
I'd suggest you read the first post in this thread: http://www.candlepowerforums.com/vb...-Easy-to-Understand-Lumens-Vs-Lux-Explanation
For the money i would look at this
http://www.candlepowerforums.com/vb/showthread.php?400766-K40Lvn-The-Must-Have-Thrower
