Fitorch
Results 1 to 20 of 20
Thread: Lumapower STRIVE-ECO supports 3xAA and 26650
    Wink2 Lumapower STRIVE-ECO supports 3xAA and 26650
    The new member of STRIVE series now ready to ship :
    The STRIVE-ECO not only support 3xAA (NiMH, Alkaline) but also high capacity 26650 (upto 73mm in length)
    The battery tube of STRIVE-ECO :
    3xAA holder included.
    SideKick UI 3.1 output control
    CLICK : power ON/OFF (click means press and release)
    HOLD (ON): change level (hold means press for more than 1 second)
    - While holding the SideKick switch for more than 1 second, it will starts to change the output level until you release it.
    HOLD (OFF) : Hold for 2 seconds to switch from Mode A and Mode B.
    Mode A: 100%, 50%, 25%,10%, 1%
    Mode B: 14Hz Strobe, SOS, 0.5Hz Light House
    MEMORY: The STRIVE ECO will memorize the last output and recall it the next power ON.SideKick UI 3.1 output control
    • While holding the SideKick switch for more than 1 second, it will starts to change the output level until you release it.
    When battery is disconnect from circuit, the SideKick switch will not power up the light.
    And the memory will restore to default setting : Ultra (100% output)
    Battery level Indication and protection.
    The SideKick switch with 2 pilot led to indicates the battery level. It will shows the battery level once every 60 seconds during power ON.
    1. GREEN : Full power, 3.6V or above
    2. GREEN blink : battery voltage lower than 3.6V
    3. RED blink : battery voltage lower than 3V, and the output will auto switch to 10%
    When battery voltage drops to 2.8V, the protection will starts and turn the light OFF.
    Retail price : USD85.
    The order link will be posted by next week
    CPFer can get the special offer : USD68.
    Order now with your CPFid will receive a FREE diffuser kit.
    Before the order link launch, you can also send PayPal to sales@lumapower.com
    Best regards,
    Ricky - Lumapower CS
    welcome to www.lumapower.com
    We do accept Paypal : sales@lumapower.com
    Default Re: Lumapower STRIVE-ECO supports 3xAA and 26650
    Hi is the AA battery holder included in this price. ..cheers
    Quote Originally Posted by lightmyfire13 View Post
    Yes, and you can use Alkaline or NiMH. Best regards, Ricky - Lumapower CS
    Should I add extra for neutral white $2 I think...cheers
    For CPFer, you can order the Neutral White at the same price.
    Best regards,
    Cheers n thanks
    Quote Originally Posted by lumapower View Post
    Best regards,
    Hi Ricky payment sent for strive NW 26650 forgot to add my cpf name light my fire 13 = xxxxxxxxx
    Flashaholic LessDark's Avatar
    Dec 2013
    Norway
    So I can't buy the new battery tube and use it for my old Strive? Is the battery tube sold separatley? I can't find it on your page.
    Warm white.
    Quote Originally Posted by LessDark View Post
    Hi LessDark,
    The upgrade parts in another thread : [CLICK HERE]
    Before we have finish online shop's update, here is the price info. for STRIVE's upgrade parts :
    1. Color Filter : RED @ USD12
    2. Color Filter : GREEN @ USD12
    3. Color Filter : BLUE @ USD12
    4. Diffuser Tip @ USD5
    5. 3xAA battery tube (also support 26650) @ USD25
    6. Tele-Force reflector Kit @ USD25
    CPFer discount :
    1. Color Filter : RED @ USD10
    2. Color Filter : GREEN @ USD10
    3. Color Filter : BLUE @ USD10
    4. Diffuser Tip @ USD4
    5. 3xAA battery tube (also support 26650) @ USD20
    6. Tele-Force reflector Kit @ USD20
    You can send PayPal to sales@lumapower.com to place the order
    Shipping Fee :
    - Normal Airmail : USD3.
    - Registered Airmail : USD5.
    - Any order value over USD20, get free shipping.
    Best regards,
    5 days from HK to UK exellent the Strive isn't bad either ...not too keen on the diffuser though ....makes a horrible yellowish colour of a nice neutral beam
    Nov 2013
    Idaho, USA
    A nice upgrade from the previous version of the Strive I own. The UI is a big improvement. And the ability to use a 73mm long protected 26650 battery is appreciated.
    Does it have reverse polarity protection?
    When will it be available in the USA, from batteryjunction.com?
    Hi SubLGT,
    While with single switch design, both terminals for battery with spring to ensure constant contact.
    So, no polarity protection.
    We have forward the product details to batteryjunction and they will prepare the web info. and then bring it to market soon.
    Best regards,
    Nov 2013
    Idaho, USA
    Hi Ricky
    Since the Strive-Eco has a larger internal body diameter than the original Strive (26650 version), will a thin battery sleeve be included with the Strive-Eco, so that a 26650 battery will not "rattle" from side to side. Or will spring pressure be enough to prevent rattling?
    P.S. I think making this flashlight compatible with AA batteries is an excellent idea.
    Hi SubLGT,
    The new battery tube with 2 internal diameter, the upper part close to the LED engine with a smaller diameter just fit the 26650.
    So that the battery is stable located inside the battery tube.
    Best regards,
    Nov 2013
    Idaho, USA
    MEMORY: The STRIVE ECO will memorize the last output and recall it the next power ON…..
    Hi Ricky, will Memory work with strobe?
    Quote Originally Posted by SubLGT View Post
    Hi SubLGT,
    Yes, it works for any selected ouput including STROBE.
    Best regards,
    Flashaholic Raybo's Avatar
    Apr 2004
    Illinois
    I don't need no stinkin' strobe!
    Looks like I will pass on this light.....
    The STROBE mode is hidden from normal cycling.
    The normal output of STRIVE-ECO in mode A cycle from different brightness.
    Best regards,
    Ricky - Lumapower
    How many lumens max and for how long? How do I order?
    Hi tcglog,
    The max. output over 800 lumens, and runtime depends on the battery capacity.
    26650 with 4500Mah can offers more than 2 hours on max. output.
    You can visit www.Lumapower.com to place your order.
    Best regards,
    Ricky - Lumapower
