HKJ
[size=+3]Windyfire 14500 800mAh (Purple)[/size]
Official specifications:
This LiIon battery is in AA size and contains about the same energy as a AA cell, but at 3 times the voltage.
The curves are not that good, the cells has about the same capacity, but not the same voltage at higher loads.
Note: The 5A curve is outside the specifications.
[size=+3]Conclusion[/size]
This cell is a disappointment, they do work up to the rated 3A, but I do not like the difference between the cells.
[size=+3]Notes and links[/size]
The batteries was supplied by Windyfire for review.
How is the test done and how to read the charts
How is a protected LiIon battery constructed
More about button top and flat top batteries
Comparison to other LiIon batteries
- Nominal capacity: 800mAh
- Nominal voltage: 3.7V
- Discharge cut-off voltage: 2.75V
- Standard charge: 4.2V 500mA
- Maximum charge current: 800mA
- Continuous discharge current: 3A
- Initial impedance max.: 70mOhm
- Cycle life: 500cycle to 60%
- Operating temperature: Charging, 0°C ~ 45°C, Discharging, -20°C~60°C
- Storage temperature: -20°c -35°c
- Weight: 20g
