Klarus
Page 1 of 12 1234567811 ... LastLast
Results 1 to 30 of 357
Thread: TM36vnM Limited Edition - The 1M Lux Reflector Thrower
    Default TM36vnM Limited Edition - The 1M Lux Reflector Thrower
    With a XPG2-R5 I was able to achieve ~900K Lux
    Now with the new XPG2-S4, harder driven, better beam tuning and improved heat sinking techniques I believe 1M Lux is achievable.
    Beam shot below is with a TM36vn XPG2-S2 VS a K40vn Fiat Lux
    I will only build 5 of these lights. More details after my vacation ;-)
    K40vn Fiat Lux VS TM36vn S2
    TM36vn S2
    TM36vnM S4 Coming Soon ;-)
    $615/$660
    I am happy to realize how happy I am. Thus, a chain reaction of happiness.
    SkyLumen54@gmail.com
    MaxBeam's Avatar
    Oct 2014
    DFW area, Texas, USA
    Default Re: TM36vnM Limited Edition - The 1M Lux Reflector Thrower
    I'll take the first one if not already spoken for and I would like to have #1 engraved on it please!
    RRJV Thrower, TM36vnM, REV Victor Enthusiast, K50vn Fiat Lux, M25C2vn Fiat Lux, Eye40vn Fiat Lux, 6XLvn, 3 Z1vn's (SBT70, MTG2, XML2) + many more
    CPF Members Map - Please Add Yourself
    MaxBeam's Avatar
    Oct 2014
    Paypal has been sent.
    Quote Originally Posted by vinhnguyen54 View Post
    Hey...you have Tmack building lasers for you now?
    Amazing!!
    GOOD TINT!
    Damn, 100 more kcd than my TM36vn? Lol. I hope it breaks a million kcd. I might need to get mine upgraded.
    Using Tapatalk
    Jan 2014
    Blue Ridge Mountains, VA
    Vinh, I already have three TM36 lights. I would be interested in having one of mine modded to one of these super bright configurations if possible.
    Since Litmous no longer makes the SBT-70, I'd also like to get the emitter back to use as a spare in case of future need on the other lights.
    More info when you get back from your vacation on the other configurations.
    Jul 2009
    Illinois
    Nice work
    ven's Avatar
    Oct 2013
    Manchester UK
    Awesome vinh
    *Flashaholic* kj2's Avatar
    The Netherlands
    That's just awesome!
    #1 2 and 3 is sold. Will take order for 2 more before sale is closed. all will have my "V54" engraving and 1-5 serial engraved.
    $600
    Thanks!
    May 2009
    WNC
    Can you upgrade mine that you modded with the new XPG2-S4?
    Quote Originally Posted by blackbalsam View Post
    This is not a simple LED upgrade. It's a complete new mod that involves all of the same work even if its just a LED swapped.
    The incredibly complicated driver must come out before the LED can. The LED is on a LED copper base and then its solder bonded onto a huge HS. There are like several layers with separate switches, adapter plug and a couple of driver layers hold together with like 6 washers, screws and retainer that must all be dissemble just to get to the LED.
    Must reverse the process to get everything back in. Check for beam and if its not good everything must be redo again. The XPG2 dedome is a tiny LED in relatively huge reflector. A tiny shift ruins the lux, and focus.
    The driver is a pain to mod too. The driver was designed to drive the much more current demanding SBT70 where there ar emore or less flexibilty with the drive. We don't have this flexibility as we are pushing the LED and heat-sinking to the very limit. Turning down the current is a must and is tricky. A bit to high pops the LED or tint shift and we loose efficiency. A bit too low and we might not hit out 1M lux goal or even 900K for that matter. A lux meter need to be used to check progress along the way. Numbers jump all over the place too. Another problem is all drivers are a little different. This is what happens when you have complicated electronics with too many parts. Too many components could builds up greater uncertainties/tolerances so every driver has to be treated independently from one another. Cant use the same exact mods for all the drivers.
    To me this light mod is like a chemistry balance equation. Beam optical physics must integrate seamlessly and balance correctly with its electronics to reach our goal.
    DriverVNX2 can be used and our problems would be greatly mitigated. However, I want the factory driver as it has great current regulation, works well with the dual stage switch design and retain the useless LCD that I kinda like. LOL
    So...Yah changing the LED in your light + driver tweaks is like a brand new mod...Tough for me to do and to charge. Therefor for this light I will only mod a brand new one. Sorry.
    Crap I forgot to calculate any shipping into the price.
    For this light its $615/$660
    Also want to add that I have no plans to build more than 5.
    So the lcd and dual switches work on this. Makes me want to sell my TM36vn and get this one, lol.
    Using Tapatalk
    Potentially Reserved. Check email
    Also count me in possibly, but have a few questions first, so please also check your email for me too.
    Look like 5 might not be enough...
    You underestimate the power of the Dark Side.
    Using Tapatalk
    Quote Originally Posted by Bigwilly View Post
    Not sure if I want to build more than 5 though...
    We will see...I will be so broke after the trip that I would probably need all the work possible LOL
    I sent you an email.
    Using Tapatalk
    I have questions about the LITE version.
    TM36vnM Lite is surprisingly $63 more than the normal battery pack version. So it's a bad deal IMO.
    Anyone buying this light does not need to pay $5 engraving. It's free with this light. Will refund those that paid.
    BTW do you know if the Lumen rating will be the same, less or more then the last version?
    Oh and BTW thanks for answering my email and my most likely is now a "YES"!
    Quote Originally Posted by crashunit007 View Post
    I have not tested it but I would be surprise if it throw more and have less lumen.
    It would be kinda crazy to push close to or more than 1000 lumen OTF from a XPG2 Dedome though don't you guys think?!
    Yes Dedome!!!! The Heck!
    You Sir, are a Jedi Master.
    My TM36vn was tested at 924 lumens so no suprise you are around 1000 lumens with the new XPG2
    Using Tapatalk
    Anyone interested in a less lux but more lumen XPL HI version?
    How much lumens and how many less lux you thinking?
    Using Tapatalk
    Do you know if the tm26 barrel will thread on to the tm36? Because I do have one of those as well . Also got mine reserved!!!!
