gunga
Hey folks, I have a new triple LED light built around the Convoy S2+ 18350 host. I built it now want to sell to buy other modding supplies to build more stuff!
The LEDs are a triple neutral Nichia 219B (Nichia NVSL219BT R85) with a 1.5 amp programmable driver from Dr Jones (lucidrv /ft with ultra low moonlight mode programmed and 5 click mode lock). They are mounted onto a custom copper pill for heat dissipation. The positive contact is a small spring so flat top cells can be used.
Levels are 0.04 to 400 lumens? (ie. Super dim moonlight mode). You can program any number of modes and the levels etc. Memory can be toggled on and off, or short cycle memory can be used.
The optic will be carlco 10508, "medium flood", with a glow sticker behind the optic! The sticker can be a choice of blue with aqua glow, pinkish red or Orange (both with orange glow), Aqua blue, or Green (in ascending order of brightness).
The clip is a custom short ti clip from ReyLight. A longer convoy stainless clip can also be substituted.
The tailcap boot is black but can be swapped for glow in the dark green or glow in the dark light blue (glows green) if desired.
If you own a Convoy S2+ 18650, often the body can be swapped to run 18650 but YMMV.
Price is $90 >> $85 shipped USA (Paypal only)
Add $6 for worldwide. Any Insurance and tracking can be added at cost.
>> SOLD <<
I can also provide a drilled 10511 (narrow smooth spot) optic with 3x green trits for $45 more.
Pictures to follow tonight?
>> SOLD <<
