Andrew Storlie
- Joined
- Jul 29, 2015
- Messages
- 34
ok so i bought the 2015 version 4000lm tm26 from amazon for 279.99 with free prime shipping. I also bought a handlebar camera mount so i can mount it to my bike as im an avid cyclist at night.
que the questions... is there a way to buy a spare battery section for the tm26, the part the batteries actually go in? reason i ask.... the battery pack i made for my last bike light uses 8x3.7v @ 12600mah lipo cells and cost me a good bit.
IF IF IF i rewire the pack from a 14.8v @ 26,200mah battery (2P4S) to a 3.7v @ 372,960mah!!! pack (8P1S) i would have 7.5 times the run time of 4x3400mah 18650 cells
3.7v X 3400mah = 12.58WH
12.58WH X 4 = 50.32WH total for 4x3400mah 18650 cells
3.7v X 12600mah = 46.62WH
46.62WH X 8 = 372.96WH total for my battery.
372.96/50.32 = 7.411.... times more runtime. so i can go on my long rides at night.
my plan for the spare battery part is to drill a hole, and wire in a connector, seal it... so when im on my bike i can use the pack, and when i take it off i can use the regular battery pack.
the hole would be drilled in either the center of the bottom or on the side facing down when screwed on all the way. i would be using a small rubber grommet and silicon on the inside to seal it up from rain water.
Any Thoughts?
Any Thoughts?
