Hello. I am replacing some bulbs in the street lights in my neighborhood. They are about 12-14 years old, and most appear to have 175watt metal halide ballasts, but the bulbs are 175watt mercury vapor. I have replaced several of the 175watt mercury vapor bulbs with the same type, and all appear to be working OK. Recently, I replaced a 175watt mercury vapor bulb with a 100watt mercury vapor bulb (still using the 175watt metal halide ballast that is installed). I was surprised to see the brightness did not appear to change noticeably, and it has been installed a couple of weeks now.
My question....is there any reason I shouldn't replace future 175watt mercury vapor bulbs, as they burn out, with the 100watt mercury vapor bulbs, continuing to use the 175watt metal halide ballast? There is a significant money savings in the cost of the bulbs, and I assume in the amount of electricity consumed. Any advise appreciated. Thanks.
