B0rt
Hi All
After lurking for a few years I am looking for a new flashlight. As I have a few decent EDC flashlights already and am totally happy with them now is the time for something "silly".
Essentially what I want is a "Pocket Throw Monster". I does not have to burn long, but it has to be VERY bright and throw far. Well, as much as that is possible for a "pocketable" light.
This is not because I actually NEED something like this but more for bragging rights (See? Mine is smaller AND brighter than all of yours!!!!1111eeleveneleven ) And because I can
What I found so far to more or less fit this description is the EagleTec TX25C. But I am sure you guys will know something even better, right?
(X) This will be ordered online (preferably from the EU due to shipping cost / customs charges).
2) Budget: An easy question, but you may change your mind after answering the rest!
(X) Up to $200.
3) Format:
(X) I want a flashlight (hand held/self contained).
4) Size:
(X) TINY - Every day carry (2-4 inches).
(X) SMALL - Every day carry (4-7 inches).
5) Emitter/Light source:
(X) LED (known for efficiency, longevity, and compactness)
6) Manufacturer:
(X) As long as I do not need powertools and/or a soldering iron to make it work I'll be fine
(X) one or two of: CR123 / 16340 / 18350 / 18650
(X) I don't care
(X) I want search and rescue type illumination (800+ lumens).
(X) SPECIAL NOTE: Burst/Turbo mode Category - There are several lights that will run at a super bright maximum for a very limited period (usually 5-10 minutes) and then will "step-down" to a lower level for thermal control. Check here if this is acceptable.
(X) Narrow Throw: I want a beam with a very tight "hot center" and minimal "side-spill". Good for distance viewing, fog, and looking through dense undergrowth.
(X) Turbohead: I want a far-distance projector with a sharply focused spot of light and minimal or zero side-spill. Good for extreme distance and impressing your friends.
(X) 150+ yards (I am searching from a helicopter)
(X) 15+ minutes on high are sufficient (5+ minutes on TURBO if applicable)
(X) Slightly Important (Walks around the neighborhood).
(X) In the end it does not matter, the other things are more important. I prefer tail mounted forward clicky. I do not like anything twisty.
(X) I want multiple light levels. (Some lights have 5-16 light levels.)
14)Material/Finish/Coating
(X) I don't care as long as it is some kind of metal.
15) Water resistance
(X) IPX4 (Splash resistant) or betterr
16) Storage conditions
(X) In house (temperature/climate controlled environment)
(X) Pocket clip, ideally bezel-down and removable
(X) Up to $200.
3) Format:
4) Size:
6) Manufacturer:
(X) I don't care
