Swagg
- Joined
- Mar 25, 2008
- Messages
- 326
I have a Cryos head with 6 trit slots and I have the 6 vials, just searching for someone that can do the install. Anybody do this type of work?
I fully understand. It is easy to fix if you mess up. I remove them (broken, dim or bubbled) with a dental pick that I heat up red hot or boiling water. Stop by your dentist office and get some old tools. They give them away.
I ship there all the time, not a problem! Here's the link to the head I have and need trits installed in: http://www.oveready.com/a-parts/bezels/cryos-cooling-bezel-copper-32-/prod_305.htmlCan you post a pic? I can do it but am in Canada.
Yes not involving borders does help. PM me an address to ship to. Thanks!gunga would do a great job for you. I can also do for you if you want to stick with USA.
Removing Norland, IMO, works best with nail polish remover. Soak the piece in nail polish remover for about 24 hours and it will make the Norland gummy and easy to remove. Never tried the boiling water but it might work as well.
phosphor, there are a few methods I use. It depends on the location of the trits and material they are installed in. If you have a HA finish you need to be super careful not to scratch things. The same is also true in Ti of course. Boiling is good option too. I usually use a combination of the hot pick and boiling. But not always depending on if you can't get the item wet. Also when you boil the Norland melts and begins to make a sticky mess. So I caution you there too. Sometimes, I will wrap the item up in that blue painters tape. It helps keep the goo off if it is a lot of Norland I am removing by boiling. I find it helps big time if a black HA and has lots of deep knurling.
But, the most used method for me, is heating a dental pick. I use a small torch and get it glowing red. I gently poke around the norland melting it until I can get the trit out. If you don't have a fine pick, I have used a thick sewing needle locked in some 4" vise grip pliers. Don't put a torch on HA or Ti. It will change the color if you hold it too long. After I pick it out, if I can boil the item, I will. Then I use a tooth pick to scrape all the remaining goo off.
Final step is cleaning with 90% alcohol. Then I inspect under a bright light for lint or debris. Check very carefully. It is easy to overlook leftover gunk. Now I am ready to install the new trits.
Hope that helps folks out.
Would it be possible for you to go in a bit more detail about how to remove dim/broken trit vials (installed with Norland 61) with a dental pick - using the two methods you mention? thanks much!
