RedLED
Will the UV LE fit in any of the following: current Mule, Makai, and Haiku with no modifications to the Haiku?
Thank you!
Thank you!
Thank you!
No, I remove the O-ring but also have to turn the metal off of the rear of the reflector in the lathe until the metal "cup" is completely gone.Do you mean just remove the small O-Ring from the back of the reflector?
Thanks
Sounds too complex for me to do if I decide to go with a Haiku head, I would order it from you Don. Still have not decided, and may go with the Sun Drop XR-U.No, I remove the O-ring but also have to turn the metal off of the rear of the reflector in the lathe until the metal "cup" is completely gone.
