HDS Systems
Page 1 of 2 12 LastLast
Results 1 to 30 of 52
Thread: Nitecore MH10, MH12, MH20 (XM-L2 1x18650/2xCR123A) in-light charging review: RUNTIME+
    Smile Nitecore MH10, MH12, MH20 (XM-L2 1x18650/2xCR123A) in-light charging review: RUNTIME+
    Reviewer's Note: This is a three-in-one review, and so is a lot more pic-heavy than usual.
    Following on the earlier 1x18650/2xCR123A models from Nitecore – the P12, P10 and EC20 – I have on hand three new models in their Multitask Hybrid family of lights, the MH10, MH12 and MH20.
    These MH-series lights are distinguished by their in-light USB battery charging feature. Aside from this, the MH10 and MH12 are very similar in design and functionality as the earlier EC20 and P12, respectively. The MH20 is a bit more distinctive, with a two-stage switch similar in feel to some of the Tiny Monster lights.
    MH10:
    MH12:
    MH20:
    Let's see how they compare.
    Common Specs:
    • LED: CREE XM-L2 U2
    • 1000 Lumen LED output
    • Uses 1 x 18650 (Included) or 2 x CR123A
    • Integrated micro-USB charging port
    • Integrated power indicator light indicates remaining battery power
    • Battery voltage display
    • Precision digital optics technology
    • Toughened ultra-clear mineral glass with anti-scratch coating
    • Constructed from aero grade aluminum alloy
    • HA III military grade hard-anodized finish
    • Constant current circuit
    • 1.5 Meter impact resistant
    • Waterproof in accordance with IPX-8 standards
    MH10 Specs:
    • Output / Runtime (18650): High: 1000 Lumens / 1 Hour 15 Minutes, Mid: 240 Lumens / 6 Hours, Low: 70 Lumens / 28 Hours, Lower: 1 Lumen / 520 Hours
    • Beam Distance: 232m
    • Peak Beam Intensity: 13500cd
    • Single button design
    • Dimensions: Length: 130mm, Head Diameter: 25.4mm, Tube Diameter: 25.4mm
    • Weight: 75g (Without Battery)
    • Includes: Nitecore NL183 2300mAh 18650 Battery, USB charging cable, Nylon Holster, Pocket Clip, Lanyard, Spare USB Port Cover, Spare O-Ring, User's Manual
    • MSRP: ~$65
    MH12 Specs:
    • Output mode/Runtime: High: 1,000 lumens / 1.25hrs, Mid: 240 lumens / 6hrs, Low: 70 lumens / 28hrs, Lower: 1 lumen / 520hrs, Strobe: 1,000 lumens / hrs
    • Peak Beam Intensity: 13,500cd
    • Max Beam Distance: 232 meters
    • Dimensions: Length: 5.47" (139mm), Bezel Diameter: 1" (25.4mm), Body Diameter: 1" (25.4mm)
    • Weight: 3.1 oz (88g) (excluding batteries)
    • Included Accessories: NL188 18650 battery, USB charging cable, holster, pocket clip, tactical ring, lanyard, spare switch cover, spare O-ring, and spare USB port cover
    • MSRP: ~$80
    MH20 Specs:
    • Output mode/Runtime: Higher: 1000 lumens / 2hrs, High: 410 lumens / 2.75hrs, Mid: 230 lumens / 5.75hrs, Low: 50 lumens / 15.75hrs, Lower: 1 lumen / 235hrs, Strobe, SOS, Location Beacon
    • Peak Beam Intensity: 12,500cd
    • Max Beam Distance: 220meters
    • Smallest, lightest 18650 USB rechargeable flashlight
    • Direct access to ultra-low and turbo outputs
    • Advanced temperature regulation (ATR) technology
    • Dimensions: Length: 4.13" (105mm), Bezel Diameter: 1.25" (31.8mm), Body Diameter: 1" (25.4mm)
    • Weight: 3.08 oz (87.3g) (excluding batteries)
    • Included Accessories: Holster, Lanyard, O-Rings, USB Cord, Pocket Clip
    • MSRP: ~$80
    MH10:
    MH12:
    [IM]http://i243.photobucket.com/albums/ff97/selfbuilt/2015/MH12%20005.jpg[/IMG]
    MH20:
    Packaging across the models is the same - Nitecore's standard thin cardboard display box, with specs and information printed right on the box. Included with each of the lights are a holster with Velcro closing flap, micro-USB charging cable, spare O-rings, basic wrist lanyard, warranty card, and manual. The MH12 also comes with a grip ring, and MH20 with a spare micro-USB port cover.
    Moreover, the MH10 comes with a Nitecore 2300mAh protected 18650 ICR battery, and the MH12 comes with a 3200mAh battery. No battery was included on my MH20.
    MH10:
    MH12:
    MH20:
    From left to right: Keeppower Protected 18650 3100mAh; Nitecore MH20, MH10, MH12, EC20, P10, P12, P10; Fenix PD35; Zebralight SC600-II.
    Nitecore MH10: Weight: 73.6g, Length: 129.5mm, Width (bezel): 25.4mm
    Nitecore MH12: Weight: 87.3g, Length: 139.5mm, Width (bezel): 25.4mm
    Nitecore MH20: Weight: 85.4g, Length: 105.5mm, Width (bezel): 31.8mm
    Nitecore EC20: Weight: 77.1g, Length: 129.2mm, Width (bezel): 25.4mm
    Nitecore P10: Weight 82.0g, Length: 135.1mm, Width (bezel): 25.5mm
    Nitecore P12: Weight: 89.7g, Length: 139.4mm, Width (bezel): 25.4mm
    Eagletac D25LC2: Weight: 50.0g, Length: 116.3mm, Width (bezel): 22.5mm
    Fenix PD35: Weight: 82.7g, Length: 138.1mm, Width (bezel): 25.4mm
    Olight S20 (2013, XM-L2): Weight: 52.4g, Length: 106.5mm, Width (bezel): 23.1mm
    Skilhunt DS20: Weight: 53.8g, Length: 110.0mm, Width (bezel): 24.0mm
    Thrunite TN12-2014: Weight: 80.0g, Length: 140.5mm, Width (bezel): 25.4mm
    Zebralight SC600 II: Weight 79.3g, Length: 101.8mm, Width (bezel) 29.7mm
    Despite the addition of the in-light charging feature, overall weight of the MH10/MH12 models are lower than the corresponding EC20/P12.
    MH10:
    MH12:
    MH20:
    All three MH-series models tested here are relatively compact for this class – although the MH20 is particular short for a 1x18650 light. It also has a wider bezel/reflector, for great throw.
    The MH10/12 look a lot like the EC20/P12 – with the main physical difference being a short flat tailcap on the MH10/EC20 instead of the larger tailcap clicky on the P12/MH12. Body styling is almost identical. Like the EC20, the MH10 has a secondary ridge to allow you to reverse the position of the pocket clip. This isn't really an option on the MH12 or MH20 – but the clip is somewhat bi-directional in its design anyway.
    Across the series, anodizing is a shiny black finish, hard anodized, with no chips or damage on my samples. Body labels are bright white and clear against the black background. Knurling is of moderate aggressiveness on the body tube and tailcap. But when combined all the other grip elements (e.g., side switch cover, fins in the head, pocket clip, etc.), I would describe overall grip as pretty good – especially so for the MH20 with its larger, grippy-textured switch.
    The main distinguishing feature of the MH-series is the built-in micro-USB port in the head – for in-light charging with the supplied USB cable. These are protected with attached rubberized dust/waterproof covers (identical design on the MH10/MH12)
    The lights have some anti-roll indentations on the body – and these work better than on the earlier lights, thanks to the rubberized port covers here.
    Tailcap screw threads are standard triangular cut and anodized for lock-out at either end of the body tube. Tailstanding is stable due to the flat tailcap. Tailcap is suitable for lanyard attachment on the MH10/12, while still allowing tailstanding. The lanyard option on the MH20 is a small hole for a split-ring or simple lanyard.
    On/off and mode switching is controlled by the tailcap clicky switch on the MH12 – and the single electronic switch in the head on the MH10/MH20. On all models the electronic switch in the head controls output selection - see below for a discussion. The MH10/MH12 uses a similar electronic switch as the EC10/P12. Switches on all models are relatively easy to locate by feel, although you may mistake the micro-USB cover on the MH10/12 by touch alone.
    Like the EC20/P12 models, there is a blue LED under the switch on the MH10/MH12 that will glow blue when the batteries are running low. It also serves as a voltage read-out function. For the MH20, there are two blue LEDs located under the switch cover. Please see my User Interface section for a discussion.
    The MH10/MH12 have a physical reverse polarity feature in the head, with the modern Nitecore design that allows "wide button top" cells to still work in the light. True flat-tops (where the positive contact is below the wrapper) won't work, but all my cells with a slightly raised contact worked fine. On the MH20, I presume that is an electronic reverse polarity detection feature, judging by the secondary contact band next to the centre contact. As such, only true button tops are likely to work on this light. For example, my AW protected 3100mAh ICR work fine in the MH20, but the Samsung 20R INR don't.
    The body tubes are wide enough to accommodate all size 18650 cells, and there seems to be plenty of room of longer cells as well. Note the MH20 has less space length space than the other models.
    The models all come with a flat black aluminum bezel. The overall head of the MH10/12 is typical for this class - not very large (and identical to EC20/ P12). The MH20 has a larger head, with a bigger reflector. Reflectors are smooth throughout (and relatively deep given the size of the heads. Coupled with the XM-L2 cool white emitters (which were well centered on all my samples), I would expect a fairly typical beam pattern for MH10/M12 – but greater throw on the MH20. Scroll down for beamshots.
    MH10
    The MH10 uses a single electronic switch interface. Fully tighten the tailcap to allow the light to function. Turn the light on/off by a click of the side switch.
    To change modes, press and hold the switch (while the light is on). Mode sequence is Lower > Lo > Med > Hi, in repeating sequence. The light has mode memory, and returns the last level set after turning the light off/on.
    Double click the switch (from either on or off) to access the blinking modes. Press and hold to advance through all the strobe modes. Mode sequence is: Strobe > Locator Beacon > SOS, in a repeating loop. A single click exits you from the blinking modes and turns off the light. Note that there is no mode memory for any of the blinking modes.
    MH12
    The MH10 uses a tailcap forward clicky switch for on/off, and an electronic side switch to change modes. Turn the light on/off by a click of the tail switch (press and hold for momentary on).
    To change modes, click the side switch (while the light is on). Mode sequence is Lower > Lo > Med > Hi, in repeating sequence. The light has mode memory, and returns the last level set after turning the light off/on at the tail switch.
    Double click the side switch to access the blinking modes. Single click the side switch to advance through all the strobe modes. Mode sequence is: Strobe > Locator Beacon > SOS, in a repeating loop. Note that there is no mode memory for any of the blinking modes.
    MH20
    The MH20 uses an updated version of Nitecore two-stage electronic switch (as found on on the P25 and TM11/TM15).
    For initial Turbo constant on, press the switch all the way and release (i.e., a full click). Turn off by a full press and release. The light has memory on this mode, and will retain the last output used (see below). Alternatively, press firmly and hold all the way down for momentary on (in Turbo), with no memory.
    Half-pressing the switch for ~1 sec (and then releasing) turns the light on in Lower (Moonlight) mode. There is no memory for this mode – it always comes on in the Lower level.
    From either method of activation, simply half-press and release the switch to advance modes. Mode sequence, in repeating order, is Lower > Lo > Med > Hi > Turbo. Turn off by a full press and release. Note that the MH20 features an additional Hi level over the MH10/MH12 (i.e., 5 levels on the MH20).
    Strobe modes can be accessed by fully holding down the switch from On for ~1 sec. To advance strobe modes, simply half-press and release the switch as you would for constant output modes. Mode sequence is Strobe > SOS > Locator Beacon, in repeating sequence. Turn off the light to exit strobe modes (there is no memory for strobe).
    Common Features
    On all models, there is a blue LED under the switch to serve as a battery readout and/or low-voltage indicator when the flashlight is on. On the MH10/MH12, once the cells are below 50% power (according to Nitecore), this indicator will flash blue every 2 seconds. It will flash faster as the power capacity drops down further. Note that this low-voltage warning feature does not seem to be implemented on the the MH20.
    Note that when first inserting cells and connecting the tailcap on the MH10/MH20, the blue LED under the switch will read out the voltage of the battery in a series of flashes (e.g., four flashes, followed by a short pause, with two more flashes would indicate a full charge of 4.2V). For the MH12, you need to hold down the side switch when clicking on at the tailcap to see this readout.
    Video:
    PWM/Strobe
    All the MH-series lights appear to be current-controlled. There was no sign of pulse width modulation (PWM) at any level, on any light.
    However, on the MH12 (and like the earlier EC20) I did detect faint re-occurring signals on the Lo and Med modes - but not the Lower or Hi modes.
    MH12 Lo:
    MH12 Med:
    MH12 Hi:
    There were no signs of this pattern on the MH10 or MH20. In any case, it is not a concern – these patterns were NOT visible by eye, even when shinning on a fan. In keeping with my standard review policy, I report on anything I can detect (whether it is visible or not). Rest assured this is not PWM, and there is no perceptible flicker on any MH-series light tested here.
    MH10 Strobe
    MH12 Strobe
    The MH10/12 have similar "tactical" strobe frequencies ~16 Hz.
    MH20 Strobe
    The MH20 has a slightly higher frequency strobe, at 20 Hz. For the other blinking modes, I am just showing the MH20 below.
    MH20 SOS
    A fairly typical SOS mode on the MH20.
    MH20 Beacon/Locator
    MH20 Beacon is a quick full-power flash, once every 2 secs.
    Standby Drain
    There is no standby drain on the MH12, thanks to the physical clicky switch for on/off. On the MH10 and MH20, there needs to be a standby current when the tailcap is connected (due to the electronic switch).
    When first connecting a battery on the MH10/12, the circuit will read out the battery voltage as a series of flashes of the blue LED under the switch. On the MH10, current during this time can be as high as ~4mA. Once the readout is finished however, current drops to a consistent 129uA standby drain on the MH10 (which is virtually identical the EC20 reviewed previously). For a 3100mAh 18650, would mean it would be fully drained in a little under 3 years. Not really much of a concern there.
    On the MH20, the final standby drain after the battery read-out was even lower, at 27uA. This would translate into over 13 years before a 3100mAh battery would be drained.
    Accidental activation can be prevented by a physical lock out of the light – simply do a quick turn of the tailcap (or head) when not in use. This is true on all models, due to the anodized threads on all lights.
    MH20 In-Light Charging
    Because the light uses a USB charging cable, I was able to take direct measures of the charging parameters using my Xtar VI01 "USB Detector" (basically a specialized USB current/voltage meter). There are many of these on the market now, and this model was favorably reviewed by HKJ here.
    For charging tests, I started with a NCR18650A 3100mAh battery (protection circuit tripped). For all these tests, I left the USB detector in place for all readings. Note that the voltage reading on this device refers to the input voltage (i.e., from the USB port).
    I am only showing the MH20 results below.
    Initial charging current and input voltage:
    For the first ~4.5 hours, there was no change in the input voltage or charging current.
    By 5 hours, it had become to drop
    By 5.5 hours:
    By 6 hours:
    By 6.5 hours:
    By 7.25 hours:
    Final resting battery voltage was only ~4.16V.
    This pattern is pretty much what I would expect from a typical CC/CV algorithm.
    Beam pattern is consistent with the earlier Nitecore lights, and about what you would expect for lights of this size. The MH20 has slightly greater throw and a wider spillbeam than the MH10/12, due to the larger reflector. Scroll down for detailed output and throw measures.
    Max output of the MH10 and MH12 is virtually identical to EC20 – with the MH20 similar to the higher max output P12. Beam distance is comparable for the smaller-headed lights, with the MH20 having a clear advantage due to its larger reflector.
    Let's see how all the levels compare across the lights on 1x18650, in my lightbox:
    The MH10 and MH12 are not too different across their various levels. Mode spacing overall is reasonable, in my view. As before, I am glad to see the ~1 lumen "Lower" mode on all models, as I personally like having low-level options in a general purpose light. This is very helpful when you have dark adapted eyes.
    The MH20's output levels are higher across the board despite the additional Hi/Turbo mode on the MH20. The extra Hi mode on the MH20 doesn't add much functionality (although may provide a runtime advantage – scroll down to see).
    Note that I am only reporting the first timed step-down for the MH10/MH12 above (the MH20 doesn't have a timed step-down). Both the EC20 and P12 had a second timed step-down (at ~41-42 mins into the runs), although to different levels. Please see the runtimes below to see how the new MH-series lights compare
    Output/Runtime Graphs:
    All my current runtimes are done with protected NCR18650A (3100mAh capacity) batteries. First, a comparison between the Hi/Turbo levels of the three new lights:
    And now how they compare to other lights on 1x18650:
    Basically, the MH10 behaves exactly the same as the EC20, and the MH12 behaves the same as the P12 (although initial max output is the same for the MH10/12). It can be hard to see in the graphs, but these four lights start to step down from Hi at ~4-5 mins, taking ~1.5 mins to reach their first defined step-down output level. A second step-down from this reduced Hi take places ~41-42 mins into the runs.
    But the real difference is that the second step-down takes you to a higher level on the EC20 and MH10 (i.e., ~340 lumens, compared to ~250 lumens on the P12/MH12). This means that total extended runtime will be less on the EC20/MH10, compared to the P12/MH12, when run on the same batteries.
    Clearly, the EC20 and MH10 are using equivalent circuits, just like the P12 and MH12 (except the initial max output of the MH12 is set to the MH10 level).
    The MH20 is completely different, with no timed step-down. Instead, you see a direct-drive like pattern on Turbo, gradually dropping in output. On Hi, you have flat-stabilized regulation for an extended period, until the battery starts to run out of power (and the lights switches to direct drive).
    Otherwise, you could consider the EC20 and P12 as roughly equivalent. These lights show very good efficiency and regulation at all levels. As I mentioned in my P12 review, I would personally like to see the first step down from Hi be available as a fifth mode (i.e., sort of Med-Hi mode).
    What about the thermal regulation on the MH20? To see how it handles heat, I have repeated the Turbo mode runtime with no cooling. Note that all my usual runtimes are done under fan cooling.
    As you can see, without cooling the MH20 ran for ~6 minutes at Turbo output, before dropping down to a reduced output level that was just below the defined Hi mode level. With some minor fluctuations it stayed at this level for the rest of the run. These results indicate the thermal sensor-mediated drop in output works as expected.
    And now runtimes on 2xRCR and 2xCR123A
    Note that only the MH20 officially supports 2xRCR on the spec sheet.
    On the MH20 on 2xCR123A, you will notice a similar unusual runtime pattern as the EC20. This is presumably due to PTC engagement. I have seen this before on a number of lights – the made-in-the-USA CR123As that I use tend to have their thermal safety features set lower than cells manufactured elsewhere. For a detailed discussion of this phenomenon, please see all the comments in this thread. It is unlikely to be an issue for most users. And at lower levels, you can expect normal operation.
    Sorry, I haven't gotten around to 2xCR123A on MH10/12.
    The MH10 and MH20 both use an electronic switch, and therefore have a standby current when connected but not on. But in both cases, this current was negligible - and can easily be broken by a simple twist of the anodized tailcap.
    There are a couple of timed step-downs from Hi on the MH10/MH12, very similar to the EC20 and P12. The MH20 lacks timed step-downs, and instead relies on thermal management to reduce output from the highest levels.
    Reported output mode levels and beam distance specs are reasonably good – but not entirely consistent. I recommend you rely on my actual output measures here for each light, in helping you choose a model.
    The rubber dust plugs covering the micro-USB ports may reduce waterproofness. I recommend you make sure these are securely in place before venturing into any wet conditions.
    Like the EC20, continued high mode operation on the MH20 may result in PTC protection limitation on some brands of CR123A cells (especially those made-in-the-USA).
    The two-stage switch interface on the MH20 gives you more versatility in how to control the light, compared to the MH10/12. But it also means you will need to take care on the timings/pressure if you have dark-adapted eyes and want to avoid Turbo.
    As previously discussed in my earlier review of the Multitask Hybrid lights from Nitecore (MH1C and MH25), the MH-series basically takes earlier models and adds a Nitecore 3.7V Li-ion battery and a built-in USB charging solution. In that sense, the MH10 and MH12 could be thought of as direct extensions for the earlier EC20 and P12. The MH20 is a novel member of the family though, with an extended range of features.
    Let's start with the MH10/MH12. Basically, you have the same circuits here as the earlier EC20 and P12 – with the only real difference being the in-light 18650 charging feature. This will be very comfortable and familiar to users of Nitecore lights, as little has changed outside of this new functionality. It adds a nice option for those who would like to be able to recharge their lights without having to use a stand-alone charger.
    In terms of the physical build of the MH10/12, quality is good across both models, with decent hand feel and ergonomics. The user interfaces are appropriate for the designs, with a good feel to the various switches. Again, these lights are basically unchanged physically from the EC20 and P12 – except for the extra rubber dust cover over the micro-USB port. As before, the low-voltage and battery read-out features of the LED under the switch are nice additions to this class.
    The MH20 is an innovative light for this class – remarkably short for an 18650 light, it reminds me of some of the early CR123A/RCR "thrower" lights in its overall dimensions (e.g., the old Lumapower D-mini). Of course, it manages that feat by skipping a physical clicky tailswitch and using just an electronic switch in the head. But the choice a two-stage switch means the added functionality of the Tiny Monster series is also available now, in a single 18650 build. The MH20 is thus a true hybrid in every sense of the word – combining features from across the Nitecore stable of lights.
    The circuit performance of the MH20 is distinctive as well, with an additional Hi level available (5-mode, unlike the 4-mode MH10/12) – and no timed step-down. Of course, this also means you won't get the same flat-stabilized performance on Turbo as you see on the MH10/12. But overall, output/runtime efficiency remains very good across the series. Based on the results here, it does indeed appear that the MH20 is using thermal management to regulate output at its highest level. Please see the runtimes above for more info on how everything compares.
    Beam pattern for the MH10/12 is unchanged from the earlier EC20/P12, with a reasonable balance between throw and spill. The larger head of the MH20 means you get a wider (but dimmer) spillbeam, with a slightly more focused hotspot.
    At the end of the day, these new MH-series models are nice in-light-charging upgrades to a couple of existing 18650 lights (the EC20 and P12). The MH20 is something new altogether in the 1x18650 space, with some features cobbled together from the Tiny Monster series of lights. I have to admit, that extra functionality of the MH20 is appealing to me – but you may prefer to stick with the simpler MH10/12 if one of those better fit your needs. Definitely nice additions to the Multitask Hybrid family from Nitecore.
    MH10, MH12, and MH20 provided by Nitecore for review.
    Default Re: Nitecore MH10, MH12, MH20 (XM-L2 1x18650/2xCR123A) in-light charging review: RUNT
    Great review as usual! 27uA on the MH20...electronic switch. No bad
    Sort of wishing I didn't sell mine, but now that the 'w' neutral white version is (kind of) out there, I may pick one up.
    GOOD TINT!
    Jul 2012
    The Nitecore MH20 is my EDC light replacing my Eagletac G25D25C2 Markll; time will tell if it can still perform over time.
    Finally some numbers!
    We all pretty much knew that the MH20 lumens are somehow innacurate on Nitecore's homepage.
    Im sure there are many things in the world that are way more interesting, but i would really like to know what went wrong when they measured it.
    ...thought about it for a sec, if they would put selfbuilts lumens into their product catalogue it would probably make 90% of their other lights look 'weakish'....maybe. You know, to the general flashlight customer i mean.
    Thanks again for the review selfbuilt!
    Flashaholic* Budda's Avatar
    Nov 2009
    Italy
    Thanks for the review.
    I was wondering about the different results I got with mine MH20
    Any Idea?
    Flashaholic* KeepingItLight's Avatar
    May 2015
    California
    Thanks for another one of your “trademark” reviews. It is top-notch, as always.
    It is nice to see that Nitecore has gotten its standby drains under control in these flashlights. I am a little disappointed to learn that the Nitecore MH20 jumps from 1 lumen to 125, with nothing in between.
    Over-discharge of Li-ion Batteries
    Of late, I have become interested in how Li-ion flashlights behave when they are driven to over-discharge. I wrote this post about it: Over-discharge of Li-ion – A Request for Flashlight Reviewers.
    Your review explains that all three of these Nitecore models flash a blue LED under their side switches when batteries run low. You do not, however, provide a direct yes-or-no statement detailing whether they have low-voltage cutoffs. I would like to see such a statement in all reviews of Li-ion flashlights.
    Based on your runtime charts for these flashlights, it looks like none of them have a low-voltage cutoff. If true, that would mean these flashlights depend on the user and/or battery protection circuits to prevent an over-discharge. On several graphs, output oscillates wildly up and down at the end of a run. That’s also how my Nitecore P36 behaves.
    If a user puts his flashlight down, and forgets that it is on, over-discharge might occur. This could happen if the battery were unprotected, and also if the circuits on a protected battery failed. During a power outage, I can envision the possibility of falling asleep while a light is still on. That, too, might lead to over-discharge. I suppose standby currents in a long-stored flashlight could also cause an over-discharge.
    Excessive Current Draw from CR123A Batteries
    Another concern I have focused on recently is high current drains from CR123A batteries. Most such batteries are rated by their manufacturers for a maximum continuous current discharge of 1.5A. Maximum “pulse” discharge is higher, typically around 3.5A.
    Does a 1000-lumen flashlight pull more than 1.5A from its CR123A batteries on its highest levels? One would think so. Is this a problem? I don’t know.
    Your runtime charts and accompanying explanation suggest that the CR123A batteries have been driven to their limit. Huge drops in output are not caused by intelligent flashlight circuits. Instead the batteries’ PTC has kicked in, forcing reduced current flow. Is this a good flashlight design?
    I would like to see charts—or, at least, tail-cap measurements of current draw—showing current demands placed on CR123A batteries. Runtime charts might show, for instance, that high current draws occur for only very short periods. Your runtime charts of output show drop-offs after only about 3 minutes. It is possible that such drains fall within the batteries’ specification as pulse currents. I do not know.
    This is a an area where I am struggling to understand better how to use CR123A batteries. For now, my inclination is to stick to lower modes where I know that current discharges do not exceed 1.5A.
    Am I being naively over-cautious?
    Thanks, once again, for your great review.
    Prince plays George Harrison's masterpiece While My Guitar Gently Weeps. R.I.P.
    Great vocals & guitar by LeAnn Rimes & Joss Stone as they cover Gershwin's Summertime.
    Flashaholic LeafSamurai's Avatar
    Oct 2014
    Christchurch, NZ
    Great review once again from selfbuilt! As we all know, the MH20 lumens are higher than what is reported by Nitecore and Selfbuilt finally confirmed it. Very interesting to note that 50 is 125, 230 is 370, 410 is 590, and 1000 is 990. It's close to double for all levels except high and turbo. The standby drain for the MH20 is also not significant, with only 27uA, which is very good for an electronic switch. Good results all around and am going to purchase the neutral white version of the MH20 now after seeing these results. Thanks Selfbuilt!
    Flashaholic* WarRaven's Avatar
    Oct 2013
    Edmonton, Alberta
    Thank you for a great multi review!
    +3
    On the MH20, pretty much as I have figured is all in your review.
    I came up about a 1k CD less, but in ball park on lumen estimates.
    Love the notation about being mindful of switch timing in a dark environment, yup turbo is nasty in pitch black.☺
    The MH20 is smoking OEM lights of similar size and looks in CD and output.
    Also as I said, it's not a gentle light, goes from moon to bright, then even brighter. I never thought I'd complain of wanting another level in-between moon and 100+, but it could sure use it.
    Edit, to clarify a bit.
    Kudos NC!
    Quote Originally Posted by Budda View Post
    Actually, that looks very much like what I found on on my non-cooled run in the review, when you account for the lower capacity 2500mAh in your test. I'm not seeing much of a difference. External cooling is required for the sustained Turbo mode.
    Quote Originally Posted by KeepingItLight View Post
    Quote Originally Posted by WarRaven View Post
    I agree, there would definitely be a place for something in between (i.e. the 30-40 lumen range would be nice).
    Yes, that is how I would interpret it too. I have not tested unprotected batteries in the light, but I presume these would continue to run down. In the runtimes above, it was likely the internal battery protection feature that triggered final shutdown.
    It is quite rare to see auto-shut-off features built into a light's circuitry - most rely on you using protected cells. Indeed, that is the whole point of the warning flashes - manufacturers typically resort to this approach, as opposed to protection shut-down levels. I can only guess that it is a difficult thing for the circuit to determine (especially in multi-power lights).
    Yes, I find it a source of concern to see PTC features kick-in on CR123A cells. I have certainly see a lot of this over the years in testing (especially common on 4xCR123A lights). Examining the cells, you can sometimes see clear evidence of damage in the wrappers around the PTC. Invariably, the worse-affected cell is the one closest to the head (where most of the heat is concentrated).
    It's fundamentally a problem of how heavily-driven lights are now on max, in general (i.e., not specific to Nitecore - or Olight, or Thunite, etc, etc.). Multi-cell CR123A setups often don't seem suitable for sustained runtimes at max levels - even in lights with thermal regulation (which is designed to protect the circuit, not the battery). But of course, that's based again on made-in-the-USA CR123A calibration levels for PTCs. With made-in-China cells, you would probably almost never see that runtime pattern.
    Ultimately, I would encourage people to use care when considering multi-cell CR123A use on any highly-driven light.
    May 2015
    California
    [Emphasis added.]
    Zebralight, of course, has them. So does the interesting new BLF A6 Special Edition. It features software written by BLF member ToyKeeper. Using a single reverse-clicky tail switch, she was able to program mode changes that go up or down (using a quick half-press for up, and a long half-press for down), as well as forced step-downs for low voltage. After stepping down to moonlight mode, the BLF A6 cuts off completely when the battery voltage hits 2.8v.
    I am not saying that every flashlight should have a low-voltage cutoff. Neither am I suggesting that every flashlight needs one. All I have asked is that reviewers include an explicit yes-no statement detailing whether a Li-ion flashlight has a low-voltage cutoff, and also that reviewers spell out precisely what happens when a flashlight is driven to over-discharge.
    My ideas are explained more fully here. They, of course, are not the last word on the subject.
    [Emphasis added.]
    Thanks for this explanation. The fact that the Chinese-made batteries use a different PTC does not mean the flashlight they are placed into draws less current! A battery that uses an inappropriate PTC is one problem. A flashlight design that pulls too much current from its CR123A batteries is another.
    When the PTC trips on your US-made batteries, do you know whether current draws have exceeded 1.5A?
    Is it a potential problem if current draws do exceed 1.5A?
    Thanks. I will.
    Aug 2014
    Fairfax Va
    Once again Selfbuilt nails the reviews to the wall! The MH20 is the nicest most well made Nitecore I have ever handled let alone purchased. I have read reports on hinky MH20 switches here and there but luckily my copy is stone cold perfect. Over the years when it comes to Nitecore I have ripped them a new one time and time again but this time is different VASTLY different with the MH20. I am impressed as hell that the MH20 actually does do 1000 lumens the thermal regulation is icing on the cake. To my eyes I see more CD but not that much more than Selfbuilt got. I consider the MH20 a new standard setter which is what all the light manufacturers are always after.
    Selfbuilt you are pleasantly humble about your top shelf light box numbers! Over the years your reviews have always reflected back my own experience with quite a few different lights. Hell I am still running 2xRCR123 in my SRT7 for max output due to the review you did on that light. I put more faith in Selfbuilt's light box than most manufacturers integrating spheres. I never thought I would say this but fantastic job Nitecore! I for once proudly carry one of your products!
    Flashaholic* akhyar's Avatar
    Mar 2013
    Malaysia
    Nitecore nails it with low parasitic drain.
    Is it because of the single electronic switch as their 2-buttons electronic switches are not so?
    Quote Originally Posted by akhyar View Post
    I presume this is just a circuit improvement with time. But note that the EC20 had the same drain as the new MH10, which are both quite reasonable. Don't know why my MH20 is even lower, but keep in mind that this is only from a single sample - it could be more variable across the line.
    Either way though, I am glad to see these low sub-mA levels.
    Mar 2013
    Malaysia
    Default Nitecore MH10, MH12, MH20 (XM-L2 1x18650/2xCR123A) in-light charging review: ...
    Some of the reviews and users impression on the new EC4, EC11/EA11 and also EC4S review sample (which use the same design 2-buttons electronic switches) show high parasitic drain (3 figures), so presumably they managed to find the right formula for single button, but not yet on 2-buttons.
    By the way, thanks or the excellent reviews
    Default Re: Nitecore MH10, MH12, MH20 (XM-L2 1x18650/2xCR123A) in-light charging review: ...
    Selfbuilt,
    Thanks for another "Gold Star" review! Your review finally settled the issue of the MH-20's strange runtime figures, especially the "50 lumen" figure.
    I think a true 40-70 lumens is a kind of "Goldilocks" level which combines excellent runtime with plenty of light for many uses. Your Nitecore P12 review showed that their claimed 70 lumens was quite accurate, and still provided nearly twice the runtime of the MH20's "50 lumens".
    Nitecore's mislabeling is puzzling. Could it be an attempt to boost sales? To the uninitiated, the MH20 may seem brighter than other lights at the "same" lumen settings, an impossibility that non-CPF'ers might not grasp.
    I'll admit to some frustration about this
    Brightnorm
    Quote Originally Posted by brightnorm View Post
    Nitecore specs are not usually so far off ... but the MH20 "50 lumen" mode was a bit of puzzler (at least on my sample). And as always, the caveat is that I am only testing n=1 sample, and it is hard to know if its representational (although it sounds in this case like it is).
    Unenlightened
    Oct 2015
    Any traffic wand lampshade can be used on MH20? Somehow I can't find them at Nitecore site.
    Quote Originally Posted by wqdeng View Post
    I don't know what they currently offer, but some other manufacturer's wand may do. Just compare the actual bezel measures here with any other light/wand.
    And
    Hi selfbuilt,
    Did you verify that the MH20 you tested does indeed have low battery warning functionality? I thought the blue lights under the switch were supposed to blink when the battery gets low and blink faster when it gets really low, but my unit does not behave this way. There is NO low battery warning! The battery was down to 3.1V and no indication. I put the battery in my P12 and it was flashing quickly just as expected. The voltage indication in the MH20 does work when the battery is first inserted indicating the proper 3.1V (three flashes followed by one flash). But the only indication of low battery when using the light is that it would turn on in moonlight or low and couldn't ramp up to any of the higher levels. Bummer, but it looks like Nitecore did not include the useful blue button low battery warning flash in the MH20! I also checked the instruction manual and it didn't say anything about this feature.
    Jim
    Flashaholic* gyzmo2002's Avatar
    Oct 2015
    Montreal, Canada
    Quote Originally Posted by jimahi View Post
    Jim
    The MH20 does not have this function.
    Sorry for my english. Acebeam k70, Armytek Predator -Dobermann Pro V3 XP-L HI and XHP35, Barracuda Pro V2 XP-L HI, Tiara A1 Pro V2 and C1 Pro V2, Wizard Pro V3 XHP50 and XPL, Partner C4 Pro v3 XHP35, Nitecore TM26, TM16GT, MH20, P12GT, SKYRC MC-3000..+++
    Nov 2014
    Marin County, CA. Out in the woods
    Not running at high levels seems like a good enough warning to me. At least it does not just suddenly turn off.
    Quote Originally Posted by gyzmo2002 View Post
    Yes, it seems the MH20 is different from the MH10/MH12 - the low-voltage warning feature is not implemented on the MH20. I've updated the UI section of the review to note this.
    Thanks for the detailed review. I was leaning towards an Olight flashlight but after reading this review I thinking of a Nitecore. Decisions? I guess this is the reason I joined this forum.
    Has anybody found a diffuser that fits the MH20?
    Quote Originally Posted by gnolivos View Post
    It is an unusual size. If you follow the DIY diffuser section of my 4xAA round-up review, you'll see I discuss using Butler Creek Blizzard flip-open scope covers (with your own diffusing material). Model #2 fits on the MH20, although it does slightly obstruct the power button. You would also need to use a few layers of electrical tape on the inside of the cover to get it to fit snug.
    Thanks as always self built. You are the best.
    Aug 2014
    Fairfax Va
    now its December and NC is slowly rolling out XP-l HI versions of some of their lights. I had swore off more lights for at least a few more months but should they roll out an MH20GT I just wont be able to help myself. I did not know the 20 did not have a low voltage warning until I read this review. I find it quite odd that NC design would leave out such an expected feature. At least I can unscrew the tube a bit screw it back in and get a voltage read out....
    I just wanted to say I bought this light and it is my favorite EDC. I am not a flashaholic like most of you are.... I own 8 lights, mostly cheap ones, but some nice 2800 lumen expensive ones too. Bottom line is, this thing is absolutely terrific. it is very bright, easily pocketable, and has a nice hotspot with plenty spill. I actually DO like the single button interface. My only complain is that the side button can be hard to find in the dark, and can be confused by the (awesome) USB charger rubber cover.
    Definitely a GREAT light!
    Question Re: Nitecore MH10, MH12, MH20 (XM-L2 1x18650/2xCR123A) in-light charging review: ...
    Selfbuilt,
    This may seem a bit* presumptuous, but do you see any way to use your influence to encourage Nitecore to lower that "50L" to achieve greater run time?
    Brightnorm
    *Maybe more than a "bit"!
    Aug 2014
    Fairfax Va
    NC seems to have gotten wise and started paying attention to the light forums. I never expected NC to start rolling out a good thermal regulation system in anything let alone very well done designs with great heat sinking like the MH20. Selfbuilts rep across the forums is stellar and NC should be aware of it. NC turned an incredible corner in 2015 something I never thought theyd do. Now for that SRT line revamp...
