Hey Guys,
Thanks in advanced for any advice I can get on this.
My Girl's Quark AA has been giving her some trouble. It won't turn on at times. I've checked it out thoroughly and have narrowed the problem to the head.
I know its in the head, because I've swapped out the Clicky with a known working one. I've changed
out the tail cap with a known 'good' tail cap. Even changed the body and tail out.
So the issue is in the head. Now on to threads and contacts. I've inspected, and cleaned all threads and contact points. And the issue still persists.
When the light won't turn on, I can give it a good wack with my hand, and it will turn on.
And the light may work fine for awhile, turning off and on again with no issues. But then
out of the blue, the issue will pop up again.
I feel like it could be a loose wire or something inside the head. Is this possible with a quark?
I haven't used anything like deoxit to clean contact points, but to the naked eye they look clean
enough to have no issue making proper contact.
I'm curious what others have to say about it. This is my girls 'favorite' EDC in the world, and the light shows it. It is heavily worn on the outside. Should I have someone open it up, and see what gives? I told her I would look into getting her light fixed. The light is at least 6 years old. She's not the original owner, so I don't know if 4sevens would warranty the light.
Any advice on what I can do, would be very much appreciated. I'll post some images of the threads and contact points.
