I have some old AA NiCD batteries. They are not used for many years. I tried to charge them on c9000. The capacity reached 3xxxmAH (battery capacity is 1100mAH) while the charger still did not stop charging. Then I manually stopped and started discharging. Capacity was only about 900mAH.
Then I tried charging them on another BT-c2000 charger. This time the problem was charger frequently stopped charging after the capacity reached 5xx mAH.
Why one charger couldn't stop while the other frequently stopped far before full charge?
And what is the efficient way to restore or activate a NiCD battery? Should I just cycle them several times (manually stop charging every time)? Should I discharge then short circuit them till 0V before charging?
