slungshot
The main purpose for this light is to find a light that can be used up close for reading in bed to seeing out around 10 yards. The main problem with a normal light is this light either needs to be a red bulb or have a red diffuser that I can add onto it.
__X__This will be mail-order or Online (location doesn't matter).
2) Budget: An easy question, but you may change your mind after answering the rest!
__X__Up to $50.
3) Format:
__X__I want a flashlight (hand held/self contained).
4) Size:
__X__TINY - Every day carry (2-4 inches).
__X__SMALL - Every day carry (4-7 inches).
5) Emitter/Light source:
__X__LED (known for efficiency, longevity, and compactness)
6) Manufacturer:
__X__I want to buy a light from a large/traditional manufacturer that is ready to go out of the box.
__X__I intend to use "Primary"/Disposable Alkaline batteries based on the usual AAA/AA/C/D sized cells common to most stores.
__X__I intend to use "Primary"/Disposable Lithium batteries based on the usual AAA/AA/C/D and CR123 sized cells common to most stores (often a cold weather or long storage choice).
__X__I want to navigate a dark room or read a map (1-10 lumens).
__X__I want an indoor "blackout" light (15-50 lumens)
__X__All Flood: I am doing "arms length" tasks like reading and campsite cooking.
__X__Less than 1 yard/meter (reading, other close work)
__X__Less than 5 yards/meters (looking for something inside a dark shed/garage/basement)
__X__30-60 minutes (I have plenty of batteries just ready to be changed)
__X__90-120 minutes (Runtime is moderately important, but still not critical)
__X__Slightly Important (Walks around the neighborhood).
Either will do:
__X__I want a body mounted switch (near the head, like on a Maglite).
__X__I want a tail mounted switch (found on the majority of today's high end lights).
__X__I want 2 light levels. (Brighter/short runtime and Dimmer/long runtime.)
14)Material/Finish/Coating
__X__Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA, is the most common material/finish for today's higher end flashlights).
15) Water resistance
__X__None needed
____IPX4 (Splash resistant)
16) Storage conditions
__X__In house (temperature/climate controlled environment)
__X__Red filter (for preserving night vision).
Must have for this light
__X__Up to $50.
3) Format:
4) Size:
6) Manufacturer:
Either will do:
__X__None needed
