Fluppeteer
- Joined
- Jan 10, 2016
- Messages
- 21
Hi all. I'm new here, but have been lurking for a few months and wanted to thank you all for providing such a useful information resource.
I come begging advice. I have a specific, odd, need for high lumen flooders: I play tiddlywinks (seriously, I'm the world number 13, you can look it up), often in pubs with poor lighting. Given a white ceiling, my plan was to point a bright flooder at it, and hence have enough light to see to play. Somewhere in the 2000 lumen range works, but the more the merrier.
So. I bought a Thrunite TN36UT, and tried Thrunite's 3400mAh cells, which as far as I can tell people have used with this light. High mode fine, turbo mode was a no-show - with either of the two sets of cells I bought.
Blaming the flashlight (because others reported similar problems), I returned it, and (partly because it seems impossible to get another TN36UT in the UK) tried a Niwalker MM15MB. Still no turbo mode, and I decided the cells couldn't be up to the current or were tripping their protectors.
So, I've since tried some efest IMR 2500mAh 20A/35A cells, some Samsung INR18650-25Rs and some LGDBHE41865s - all new and all just charged. Good news, they all activate turbo mode on the MM15MB. Bad news, for less than a minute. I was expecting about ten minutes and for the flashlight to get warm to touch before it cuts out. It barely does. The power switch LED IS red, which could mean the batteries are somehow inadequate (according to Niwalker's manual), but it's red as soon as the flashlight is on, in any mode, and other modes work fine. The TN36UT's switch LED suggested the cells were ok. I now have a lot of cells (not by the standards of this forum, but...) and an expensive 2600 lumen flashlight with brief delusions of 6800 lumens. For what it's worth, the light is cutting out, not stepping down to "high". Even in 2600 lumen mode, the light cuts out after about half an hour, not the 2.8 hours Niwalker suggests (I'd expect less from a lower capacity battery, but not this much - I suspect thermals again, especially since the flashlight can go back on after a few minutes).
Question: Is a few seconds normal runtime in turbo for these flooders, or is there something wrong with the thermals of my MM15MB in addition to my battery troubles? Is it worth trying to return it (to Hong Kong!) out is this within expectations? I'm considering getting another TN36UT when I'm in the US (where they're easier to access) next week, but will go for something less exotic if turbo is going to be so transient. Or am I unwittingly using inadequate cells?
Thanks for any illumination you can provide to my situation!
- Andrew Garrard
(Forum newbie, MM15MB, Eagtac GX30L2R, TN Ti3, TN 2C V2+18350)
- Andrew Garrard
