Three vehicles, a 2003 Silverado, 2012 F-150 and 2007 Toyota Tacoma. All use the 3157A or 4157N as their front turn signal the Silverado uses the higher 14 volt bulb as a DRL...the 4114 white color bulb.
For the sake of my question let's say that F-150 and Tacoma produce 12.8 volts while the Silverado is one of the vehicles that the 14 volt bulbs were designed for. While it is presumed on the basis of Mr. Stern's writing that the 14volt bulb will be more than fine for the Silverado, I have questions about the suitability of using this bulb in a vehicle that is designed for 12.8 filament bulbs.
There is no doubt that 5702KA bulb is a very, very long life bulb, but will the results be suitable for turn signal/DRL use in "normal voltage" vehicles when using the DRL-1?
While many posts here are cautioned that to get increased brightness you trade longevity, I am wondering if the 5702KA trades long life for too little brightness in the 12.8 volt systems?
