880 Lumens Zooming Flashlight with Convex Lens
--CREE XM-L2 U3--
Features
● CREE XM-L2 U3 LED, with a lifetime of up to 50,000 hours;
● Slightly depress the tail cap switch to turn on/off the flashlight as well as selecting desired output mode:
Turbo (880 lumens, automatically lowers to High after 3 mins continuous use); High (480 lumens, 2 hrs ); Mid (200 lumens, 6 hrs ); Low (17 lumens, 60 hrs ); Strobe, SOS, Aviation Signal
● Constant current circuit, constant output
● Uses one single 18650 or two CR123A batteries
● Working voltage: 2.8~8.4V
● Convex lens with as high as 97% light transmittance
● Dimensions: 150mm (length) x 45mm (head diameter) x 26mm (tail diameter)
● Weight:150g(battery excluded)
● Aerospace-grade aluminum alloy, Stainless Steel retaining ring on the top
● Military Specification Type III- hard anodized body
● Waterproof, in accordance with IPX-8 standard
● Accessories: Lanyard ,O-rings
Please visit our homepage for more details, thanks.
--CREE XM-L2 U3--
Features
