I've had a green Photon II on my keychain for years and years and it's pretty dim, though still useable. I decided to finally get around to changing the cells. I scrounged a pair of 2016's out of a white Countycomm light whose LED had gone dead (odd, I'll make another post about that) and opened up the Photon II. To my surprise, instead of a pair of 2016's there was a 2032 inside. It's been running on 3 volts all along. I don't remember for sure if it's always been dim. I don't have a decent way to test the 2032. I'll have some more Countycomm lights soon so may swap in another 2032.
Anyone know what's going on here? Is there such thing as a low Vf green LED? I do think I've seen some spec'd at 2.4 volts or so, but they were low intensity. Did LRI (Photon) switch to using two 2016's for the green sometime along the way? Did they switch LED's as well?
I do have some vague recollection of this from the dim past. When I first bought my Photons I bought a green one and a white one, and I now sort of remember that the green one was supposed to have much longer battery life. In fact the white one crapped out rather early--the things switch on and off by the springiness of the LED lead, and the lead lost its springiness so the white light got stuck "on" and drained its cells. It's sort of a lame design. If I buy any more high class coin cell lights I'll probably try Inova Microlights or CMG O-4's.
