Sold/Expired FS: p60 triple dropin (SOLD)
vinte77
California
For sale: bushwacked copper p60 shell w/ XP-L HI U5 4000K LEDs on NOCTIGON 3XP MCPCB, 10507 carclo-optic, potted with thermal cubes, and FET driver w/ bypassed spring (guppydrv v.2 programmable firmware). The dropin has some scratches from being handled and tested (copper is easy to scratch).
This dropin can only be run on a single cell, ideally a high drain cell to make best use of the FET driver for the most lumen output.
I'm looking to get $80.00 paypalled and shipped.
Universal guppydrvThis firmware allows up to 20 built-in mode groups, that the user can select via a series of button presses and a user programmable turbo timer that will automatically step the power down to 50% after the set time is hit.
Low voltage protection: With 1S cells the light will begin to step down output at around 2.8v under load. The light will not shut completely off, but will continue to run at a moonlight level.
Rev.2 User Selectable Groups:
  1. 100% Only
  2. 5% - 100% | Memory
  3. 5% - 100% | No Memory
  4. 30% - 100% | Memory
  5. 30% - 100% | No Memory
  6. 70% - 100% | Memory
  7. 70% - 100% | No Memory
  8. ML - 30% - 100% | Memory
  9. ML - 30% - 100% | No Memory
  10. 100% - 30% - ML | No Memory
  11. ML - 5% - 15% - 50% - 70% - 100% | Memory
  12. ML - 5% - 15% - 50% - 70% - 100% | No Memory
  13. 100% - 70% - 50% - 15% - 5% - ML | No Memory
  14. Strobe Only
  15. 100% - Strobe | No Memory
  16. Strobe - 100% | No Memory
  17. 100% - 1Hz Blink | No Memory
  18. ML - 5% - 30% - 70% - 100% - Strobe - 1Hz Blink | No Memory
  19. 100% - 70% - 30% - 5% - ML - Strobe - 1Hz Blink | No Memory
  20. 5% - 30% - 100% - 1Hz Blink - 3Hz Blink - Strobe - Beacon | No Memory
Guppydrv ​Instructions
To switch mode groups: rapidly tap the switch 8 times, the light will then enter the programming mode and begin to flash. With the light in programming mode, tap the switch the same number of times as your desired mode group. The light will blink and your mode group will be memorized.
To set the turbo timer: rapidly tap the switch 8 times, the light will then enter the programming mode and begin to flash. With the light in programming mode, tap the switch 30 times to enter the turbo timer set mode. The light will then switch to 100% power. When the light is at the desired temperature for the turbo step down, turn the light off. The turbo timer will then be set. The turbo timer steps the light down to 50% regardless of the mode group set.
