Ok then so not really an upgrade to what I have. Use my VC 2 Plus as a ups power pack and try and catch it at 3.6V. If I do not catch it and leave it till it cuts itself off at 3.10V so no danger of over discharge.
I am pretty sure I am being overly concerned with rotating fully charged cells out more often them is nessesary but I enjoy messing around with the charger and batteries.
3.1v is not over discharge, without splitting hairs, maybe 30-40% left in the tank at 3.6v , cell dependent........My mods work down to 3.3v so there is enough in the tank to supply 9a for 5-8s bursts.....
Most cells are rated at 2.5 or 2.7v min, so past that is over discharged and even then its not the end of the world...........as long as its not left for a long period, it will charge up fine!
3.6v is a nice V as it gives a good buffer, reduces the charging time back to 4.2v and is also a part cycle(not a full cycle). So again without getting anal, charging back up at 3.6v could be argued its 1/2 a cycle, cell may be rated at 300 cycles, so 600 part cycles .............many years of use from an $8 ish cell.........
Learn the light, before you know it you will be guessing the V before it goes on charge!!!
Remember that the 3500mah or 3000mah(cell dependent) is measured from say 2.5v to 4.2v which many will get no where near!!! So if a 3000mah is a good bit cheaper than a 3500mah cell, there is no real reason imho to spend the extra premium unless you use your cells right down. I know there is a little more to it than that, just keeping it simple(all be it a rough round the edges example).
So maybe your new light, use it and check the V after 30m of use, use again and so on, build up a rough idea of use time , then charge back up. Thats all i do, dont have time (nor enough interest to get really anal). I am interested in cells and chargers, no question there and kind of a little hobby in itself, but having a life and time restrictions lean me more to just using common sense and enjoying them. Yet to happen, but if i do ruin a cell, its not exactly like a big expense to replace........imo!
Dont worry about being overly concerned at the start, lots to take in, soon fall in place and you will just enjoy them for what they are..........high performance food for your lights
Most fun way of storing at 3.6v is using the light to achieve that nominal voltage
