Surefire E-series Click Switch Momentary-only Mod
m4a1usr
Washington State
An interesting vid concerning the disassembly of the most common Surefire "clicky". Good for futrue reference if nothing else. Often that SF switch will fail and the issue typically is the spring inside the contact plunger. And the fix turns out to be relatively simple. Just use the plunger spring from a Judco J188 switch. Works great.
