The Fenix-Store
Results 1 to 3 of 3
Thread: Review Thorfire C8s: Thrower, XM-L2, 900 lumens, 1x18650; (beam)shots, compare
    Flashaholic* kj75's Avatar
    Sep 2012
    The Netherlands
    Arrow Review Thorfire C8s: Thrower, XM-L2, 900 lumens, 1x18650; (beam)shots, compare
    Another Thorfire just came in: the C8s. This light isn’t brand-new, but Thorfire has redesigned and updated the LED of this popular and cheap pocket thrower. Also the overall and build-quality should have been improved. In this review I’ll show you the details and the output of the C8s, also compared to some equal lights. Let’s have a look and see if this Thorfire is worth its money!
    the Thorfire C8s
    a pocket-sized thrower
    powered by a XM-L2 LED
    a budget light
    that has good performance
    and good throw
    To start with, the features and specifications here, given by Thorfire:
    • Uses Cree XM-L2 LED with a lifespan of 20 years.
    • Uses one 18650 3.7v battery or two CR123A batteries ( 18650 battery Included).
    • Tail tap switch for on/off and output selection.
    • Made of Aircraft-grade Aluminum.
    • High-efficiency reflection lens.
    • Max 900 Lumens output.
    The dimensions:
    • Length: approx. 143mm
    • Head diameter: 44.5mm
    • Body diameter: 25.4mm
    • Weight: 145grams (without battery)
    And the output specs:
    • Moonlight: 0,5 lumens
    • Low: 30 lumens
    • Mid: 280 lumens
    • High: 900 lumens
    Unboxing:
    For this price, you can’t expect an exclusive box here. The C8s comes in a simple carton, that is sturdy enough to protect the light during transport / shipping. Not a lot of accessories inside: Only the parts that are necessary. No nothing special here, but the light came in without defects of damage. Have a look at the pictures below that show the carton and the contents!
    a simple light-brown carton
    with little information on the sticker
    inside: Thorfire C8s, manual, lanyard and spare o-rings
    Impressions:
    Like I mentioned earlier in several reviews, a Thorfire feels real good for its price! The C8s is a medium-sized flashlight, that has a “classic” design that I (personally) like. It has a rather thick tube, feels little heavy and is built well. Checking the lights’ exterior there’s nothing to complain about the anodizing and finishing job. The overall build-quality is (again) well-done: Sturdy materials used, no sharp parts, and I couldn’t find any chips or defects at the anodization either. Also the laser-engraving is clear and well-done.The relatively big head has deep fins that prevent against overheating. Moreover, this bigger head (in combination with the texture at the body) will ensure good grip. Tail standing is possible and stable. Thanks to the notches in the lights’ head, the C8s has a very good anti-rolling design. At the tail a double lanyard-hole, that is a good point. The button/clicky has (to) soft feels. The lens is clean, but a coating is missing. I detected some chips at the edge of the reflector, for the rest its clean and dust-free. The XM-L2 LED is well-centered. The threads (that run smoothly) were not lubed at my light, please mind to do it yourself. . Inside the head I saw some solder-rests; it is finished sufficiently here, but not perfect. The tube is clean and into the cap it looks ok.
    So, summarizing, we have nothing to complain about the machining and finishing of the C8s; only some things at the finishing could be improved. Scroll down to see my pictures that show the details of the light!
    the C8s has classic looks
    and nice, balanced proportions
    a big head relative to the body
    a smooth and deep reflector
    stable standing
    also tailstanding is no problem
    easy to handle with
    excellent anti rolling design thanks to the notches
    no coating at the lens
    the body-texture doesn’t provide that much grip
    well done: double lanyard holes
    excellent engraving-job
    anodizing well-done
    deep fins to prevent against overheating
    two battery-options: 2 x CR123A or one 18650
    the xm-l2 LED is well-centered
    a look inside the head: a sturdy spring, but sharp edges and some solder-rests
    the threads are well-machined; little glue rests in the cap
    the C8s in three parts
    the lanyard added-on
    overall build-quality is good
    and the well-centered LED is needed for a thrower like this one is
    value for money
    User interface:
    Often (compact) throwers are easy to handle with because they have big heads a rather small tubes. Also the C8s fits well in the hand and thanks to the big head it won’t slip out of it. The body texture is “fine-grained” and will not help that much to have better grip. The “soft-feeling” button is easy to locate, even in complete darkness.
    The C8s has one button for all. About the interface of the C8s: I don’t like it. Main issue for that is the lack of momentary on. For on/off there always a full click needed. So, please add this in future.
    When turning on, tap the button to cycle through the four normal modes. This works fine. The C8s has mode memory, but only if the mode is used longer than 3 seconds. If you turn on-off-on within three seconds, the light will start at next mode in which you turned off. A bit strange… To enter strobe-mode, you have to tap twice quickly. This needs a lot of exercise, and I failed regularly. This isn’t ideal when you’re in a stressful situation.
    All-in-all, technical the interface works fine and without problems, but it’s not my favorite. I would recommend Thorfire to edit the interface.
    Modes:
    The C8s has in total four normal modes and one special. The four are: MOONLIGHT > LOW > MED > HIGH. The spacing is good for a thrower-light like this. No instant normal-modes found at the C8s.
    The special mode is STROBE, that has one frequency. Neither instant-STROBE at the C8s. No voltage indication or low-power warning at this light. To LOCK-OUT the C8s, release the tailcap a little.
    Size comparison:
    The C8s shown here together with its brother VG10 and another compact thrower, the Nitecore EC4, that has about the same dimensions and equal throw.
    18650-cell, Thorfire VG10, Thorfire C8S and Nitecore EC4
    the heads: XM-L2 and XM-L2(U2) at right side
    the tails:
    Tint:
    The C8s has the coldest tint here: Shown together with the VG10 and the Nitecore EC4 you see a really cool tint with some blue in the spill. The Thorfire VG10 has a more neutral tint, the Nitecore EC4 looks greenish. All lights are in about equal output mode, this shows also the beamprofiles; the C8s will “throw-out” the VG10-brother easily.
    Beamprofile:
    The C8s is designed for throw, and that is what you can see at the beam. The smooth and deep reflector creates a big and bright spot, almost no corona and big, equal spill. This makes the C8s a mid-range searchlight that can be used best in the range of 100-150 meters. At shorter distance (indoors), I discovered some rings around the beam. For the rest, a beam without defects; no PWM detected at any mode.
    Showing the beamprofile and the four output-modes of the C8s here; the distance to the wall is about 1 meter.
    Camera-settings: ISO100, F/2.7, WB daylight, 1/125 sec, 35mm
    GIF-picture:
    Going outdoor with the C8s. First shown here the four output modes. The lowest mode is barely noticeable at the picture; there’s a rather big jump between the low and med mode.
    Camera-settings: ISO100, F/2.7, WB daylight, 4 sec, 35mm
    GIF-picture:
    A shoot-out against the VG10-brother; nice to see here that a larger and deeper reflector gives so different beam while using the same LED.
    Thorfire VG10 against the Thorfire C8s
    A comparison against the Nitecore EC4, that has better output because it uses two 18650’s. The C8s does a good job at throw here.
    Thorfire C8s against the Nitecore EC4
    Conclusion:
    At the end of this review I can tell you this light is a really good pick in its class. The overall quality and finishing is good, is easy to handle with and fits nicely in the hand and has good throw too. What I don’t like is the interface: I would like to see momentary-on and some instant modes.
    What I’m most curious to: How would this light perform using a XP-L HI LED? So, I’ll ask Thorfire: Don’t let wait us to long…
    Thanks to Thorfire for the proper shipping!
    Default Re: Review Thorfire C8s: Thrower, XM-L2, 900 lumens, 1x18650; (beam)shots, compare
    Thank you for the review. Posting my experience for anyone who comes across your review. I ordered 2 of these after I dropped my rigid halo 800 into a huge tank of oil. Figured for $20 couldnt go wrong. One light has been rock solid steady since new, the other failed after 1 charge on the battery. I tried a handful of other batteries and couldnt make the light power on with any of them. I contacted the seller on Amazon. They replied in an hour (with terrible english, but great response time). I sent them a link to my collection of lights and told them about the number of batteries I tried. They immediately shipped me another one without question. It should be here any day now. Hopefully the other one I bought with the now failed light lasts longer, but +1 for the quick courteous customer service with the warranty claim.
    Quote Originally Posted by yellowdogyellowsnow View Post
    I have used 2x ThorFire C8S for more than one year. I put them through a lot while they served as the headlights on my mountainbike. Here is a little video review:
    I like that they dissipate the heat well and are a 100% water resistant.
