Miboxer
Page 1 of 2 12 LastLast
Results 1 to 30 of 40
Thread: What's the best 18350 rechargeable battery?
    Dec 2004
    Northern Virginia
    Default What's the best 18350 rechargeable battery?
    I am looking at 3.7V.
    I run a Malkoff in a "3P" FiveMega body and want to take advantage of the 18mm body. I currently run a 16340 and it works ok but want something with more capacity, I understand there is a 30% difference.
    Malkoff Devices!
    Flashaholic* ChrisGarrett's Avatar
    Feb 2012
    Miami, Florida
    Default Re: What's the best 18350 rechargeable battery?
    Quote Originally Posted by etc View Post
    Either the Keeppower IMR 18350, or the AWT IMR, if you're pulling more than 2A. I bought two of the AWTs when I got the 18350 body for my Convoy S2+ Triple XP-L that Ven got me earlier in the year. That driver pulls 6A, so I needed an IMR cell. I get about 8 minutes on 6A turbo with the 800mAh AWTs, which tested pretty good on my Opus 3400.
    Either should be fine to fiddle with and they're not too spendy.
    Chris
    Convoy: S2, S2+, M1, M2, Fenix: P1D, PD32, HL30, ET: D25C Ti, SF: 6P, ZL: SC-600, Klarus: P2A, Jetbeam: BA-20, Icon: Rogue 1, L3: L10, Xeno: E03, ShiningBeam: I-Mini, Olight: i3s, SWM: D40A, M11R, V11R, Maglite: 6Ds, MMs, Solitaires, LaCrosse BC-700, Maha C-9000, XTAR VP2, MP1S, XP1, MC1+, WP2 II, NiteCore i4, v2.
    Dec 2004
    Northern Virginia
    I am running it with a lowly Malkoff M61LL so don't need more than 150 mah or whatever it pulls. don't need IMR. Is there a 'regular' 18mm version?
    Malkoff Devices!
    Feb 2012
    Miami, Florida
    It looks like Efest makes an 'ICR' of some sort.
    You can look through them here:
    http://lygte-info.dk/review/batterie...Test%20UK.html
    Chris
    Mar 2006
    Anaheim, CA.
    I prefer Keeppower or Efest.
    Dec 2004
    Northern Virginia
    Is there a non-protected version?
    Malkoff Devices!
    18350 that's a little battery.
    Fenix TK50,TK41,TK40,L2D,L1D,L0D,LD01,LD41,LD20,LD15,LD1 0,LD05,HP10,HP15|ZebraLight SC51,SC62w,SC600w,SC600Fd|EagleTac D25A,D25A2,MX25L3C,T25C2,D25LC2|Nitecore TM16,EAX,MT1A,MT2A,EZ AA,IFD2,T5s,D4|47's Mini AA,AA²,"X"AA²,Pro QPA|JetBeam E3S|Spark SD52-NW,SD73-CW, SD6-460-NW,SL6-740NW| List of Lights
    Dec 2004
    Northern Virginia
    Because surefire 3p is a little lite.
    Malkoff Devices!
    Mar 2006
    Anaheim, CA.
    http://www.batteryjunction.com/efest-3712-button.html
    Flashaholic* ShineOnYouCrazyDiamond's Avatar
    Aug 2009
    CT, USA
    In the size you are looking I don't think you'll find ICR chemistry 18350s that will give you more runtime than IMR cells (even with claimed capacities). I like the AW 800mAh 18350 cells. The eFest purple 18350 cells are good too. I've read good things about the Keepower but don't have any hands-on experience with them.
    Just a friendly reminder - keep in mind with the drop-in you are referring to there is no LVC, and with the low current draw you could drain a cell too far without knowing it. IMR would be the more forgiving chemistry for this scenario.
    Jul 2014
    Australia
    I run the same (but would NEVER call it "lowly") Malkoff, I use AW 18350 IMR and have had very good and long life out of these batteries.
    Feb 2012
    Miami, Florida
    No, except for the IMRs. At this point, you're better off with the known quality of the IMRs, because they're more popular. Look how craptastic the Efest 900 ICR was in HKJ's test?
    Theoretically, you might lose a couple of minutes of capacity, but you're getting halfway decent cells, that utilize a 'somewhat' safer chemistry.
    These small cells mostly all come from anonymous factories in China, so in this case, name brands might be tellingly important.
    Chris
    Dec 2004
    Northern Virginia
    Quote Originally Posted by ShineOnYouCrazyDiamond View Post
    that's a good point... I almost always run cells without a protection circuit and got used to swapping them on a regular basis.
    Malkoff Devices!
    Dec 2004
    Northern Virginia
    Quote Originally Posted by Strintguy View Post
    It was obviously sarcasm.. I've had my first Malkoff for 7 years and still use it on a regular basis. M60L mates really with a 3P and 18350.
    Malkoff Devices!
    Nov 2013
    Idaho, USA
    Dec 2004
    Northern Virginia
    Cool thanks.
    Seems capacity goes down as Amps increase. Who runs anything at 10A?
    Malkoff Devices!
    Feb 2012
    Miami, Florida
    Cool thanks.
    Not 10A, but my 3Tronics triple XP-L HI mentioned above, direct drives at a measured (by me) 6A on its highest/turbo mode and that's getting up there for a light running a small cell.
    Chris
    Xtar IMR18350. Using them more than 2 years, no degradation in performance.
    Dec 2004
    Northern Virginia
    cool. Source?
    Re: Xtar IMR18350
    Malkoff Devices!
    I bought them on ebay from seller xtardirect or xtar-usa, don't remember now, but can check if necessary. Bought also IMR 14500 and protected 18650 xtar cells from him.
    Dec 2004
    Northern Virginia
    That's what I ended up getting.
    Malkoff Devices!
    Feb 2012
    Miami, Florida
    Ooops.
    You did not consult the 'Battery Bible.'
    http://lygte-info.dk/review/batterie...2014%20UK.html
    Should have gone with the AWTs.
    Chris
    And in that "bible", Xtar outperforms AWT.
    Dec 2004
    Northern Virginia
    this is for very low amps, not even close to 1A. More like 60-100 mAh.
    don't need high performance stuff.
    Malkoff Devices!
    Feb 2012
    Miami, Florida
    Quote Originally Posted by CuriousOne View Post
    Not at 6A, it doesn't, which is what I need.
    Chris
    Because it is low drain type. There's also high drain IMR18350 XTAR, which outperforms AWT, AW - tested by myself.
    ven's Avatar
    Oct 2013
    Manchester UK
    Not saying best, but had good results with these
    I dont think there is that much choice in this size anyway, would guess most good branded ones are the same IMR cell under the different wrap. Certainly not spoiled like we are with 18650 flavours.................
    Flashaholic* akhyar's Avatar
    Mar 2013
    Malaysia
    ^ +1
    Has a few of the black Keeppower IMR myself and no problem running them from my Convoy S2+ to my quad Astrolux S41
    I'm finishing my pulse load rig, so I guess, shortly I will be able to pulse load test these cells, and see, what they are worth.
    Dec 2004
    Northern Virginia
    Quote Originally Posted by ChrisGarrett View Post
    Ooops.
    Chris
    Yeah but they say 900 mAh instead of 750 or 800 mAh.
    Malkoff Devices!
