Acebeam
Page 1 of 4 1234 LastLast
Results 1 to 30 of 105
Thread: Titanium Boot Retaining Rings to fit Mac & Sigma EDC lights
    Default Titanium Boot Retaining Rings to fit Mac, Sigma, HMW Tridents
    Welcome to the first Official Offering from BratGuy Enterprises!
    Ti Boot Retaining Rings
    Made to same specs as McClicky, so should work anywhere a riing in used to hold a boot in with a McClicky!
    These rings should work in the following lights (if equipped with a boot ring):
    Mac's Customs EDC/Tri-EDC, XM-L series
    Hanko Machine Works Trident
    Sigma Customs (thetasigma)
    BratGuy Enterprises (mcbrat)
    TM Design & Fabrication (DaFabricata)
    This set will be slotted instead of having the tiny holes.
    No stonewashing with this design (the slot stays shiny)
    Unfortunately, my costs went up considerable on this batch, so p[rice has been adjusted accordingly.
    Rings will be sandwiched between two index cards, and mailed in a small standard security envelope.
    Pricing: $22.00 each.
    Paypal (goods/services) is: bratguyenterprises@gmail.com
    Availability: Available (see below)
    Batch 2 Run (Interest List):
    Num:Who
    1-Zernan Golez - shipped
    2-Zernan Golez - shipped
    3-David Craig - shipped
    4-David Craig - shipped
    5-David Craig - shipped
    6-David Craig - shipped
    7-emu124 - shipped
    8-emu124 - shipped
    9-emu124 - shipped
    10-sigfan - shipped
    11-Ryan Sloan - shipped
    12-easilyled - shipped
    13-easilyled - shipped
    14-easilyled - shipped
    15-Yone - shipped
    16-Yone - shipped
    17-Yone - shipped
    18-easilyled - shipped
    19-easilyled - shipped
    20-Ryan Sloan - shipped
    Still more available.....
    Batch 1 Info:
    Created originally to fit Mac's Customs Tri-EDC and EDC lights, however these rings were made to the proper 11/16-20 UN thread specs, but it seems not all of Mac's lights were made to the proper spec.
    The McClicky switch is way under spec for that thread size, and it looks like Mac's lights were made to fit the undersized spec of the McClicky, but it varied from light to light.
    Unfortunately, this batch will not work in Mac Ti or Damascus lights. I've not found one of the Mac's Ti EDC or Tri-EDC lights that they fit. The machine shop and I have been discussing option for the next set to be sized to the McClicky so they will work with the Ti lights, and we will also be doing something different for the install holes. That batch may not have the quantity to get this same price though...
    These have fit every copper light I've had, and most of the aluminum and brass, but not all.
    With the Brass or Aluminum lights, the internal threads could be cleaned up with a standard bottoming tap if you have access to one, or possibly you could use a small round file to flatten down the tops of the threads in the light.
    These rings will also work in the Sigma Customs lights, as Devin uses a tap for the threads, so they are to spec.
    I don't have a Hanko Trident to try them in, but in theory they should work in them as well if the retaining ring on them is to the thread spec, and not the McClicky specs (undersized).
    These are made basically the same way the stock Delrin ones were made, in that a long rod is bored and threaded, then each ring is parted off. because of this some look like the hole is not centered (just like the stock rings), but it's just an optical illusion because of where the threads are visible. if you hold a ring up to a back light, you can see it's uniform.
    These just have 4 small holes to screw in with. size of the holes was a limitation because of the landing area with the threading, they visibly look smaller than the stock ones, but I've always used a curved nose tweezers for these rings, and it works fine for these as well.
    Blasted finish was just a test. a couple have marks from test fitting, and due to the nature of how these install, there won't be any more blasted ones.
    Batch 1 Run: SOLD OUT
    Raw machined finish - ALL SOLD
    Stone Washed finish - ALL SOLD
    Blasted ALL SOLD
    1. DellSuperman
    2. DellSuperman
    3. ThetaSigma
    4. ThetaSigma
    5. write2dgray
    6. write2dgray
    7. whizdumb
    Post your "I'll Take it" with item/qty info in this thread, then follow up with Paypal
    I also still have some bare pills available...
    http://www.candlepowerforums.com/vb/...ills-for-Mac-s
    Flashaholic* DellSuperman's Avatar
    Dec 2012
    Singapore
    Default Re: Titanium Boot Retaining Rings to fit Mac & Sigma EDC lights
    Ill take 2 x blasted & 1 x raw please!
    *edit* payment sent..
    Flashaholic* Thetasigma's Avatar
    Nov 2015
    Michigan, USA
    Regarding the holes, you might consider a milled slot across instead of drilled holes.
    I'll take 2 blasted rings, paypal incoming.
    Quote Originally Posted by Thetasigma View Post
    definitely was one of the options we were looking at.
    removing duplicate post....
    Flashaholic write2dgray's Avatar
    Mar 2009
    Princeton, NJ
    2 x blasted please
    I have a sigma coming sometime soon. I'd like 1 blasted version. Paypal Sent.
    Edit:
    I also sent payment for a raw ring for one of my Mac's Customs.
    Thanks
    all the blasted ones are gone now. I'll see about doing a stone wash on some to see how it looks...
    Paypal sent for one raw ti
    ill wait to see what stonewash looks like b4 i grab my 2nd
    all items paid for already are going out this morning.
    I have a batch of 10 rings in the tumbler right now, so we'll see how this turns out
    Feb 2014
    Rural Saskatchewan, Canada
    In for 2 stone washed please.
    Edit: payment sent.
    well, it looks pretty good I think...
    *Flashaholic* gunga's Avatar
    Nov 2006
    Vancouver, BC, Canada
    Default Titanium Boot Retaining Rings to fit Mac & Sigma EDC lights
    Sigh. I wasn't going to do it, I don't really need it, but stone washed is nice. I'll take a stone washed, shipped to Canada. The delrin ring is my least favourite part of my sigma.
    Edit: Paypal sent.
    Ill take one stonewashed. Paypal sent, Cheers!
    Jan 2014
    Louisiana
    I'll take 1 raw Ti… PP sent.
    thanks. next batch is getting mailed out Tuesday!
    Hope I'll be fast enough on tuesday, then.
    may I reserve one mc?
    I'll take one Stone-washed ring.
    I mailed out 4 orders today. I have plenty. I did another batch of Stonewashed. What light is it going into?
    I have one copper tri and one Ti Mac EDC xm-l.
    Nice. PayPal info is listed in first post...
    Mar 2009
    Princeton, NJ
    Received - thanks McBrat Ent.!
    Perfect fit in an aluminum Mac , no-go as expected in a Ti EDC.
    Quick pic
    oooh. I like that gray boot!
    Flashaholic* Ladd's Avatar
    Jan 2015
    US
    I'll take one machine finish (and a Cu pill)
    Thanks, CPF!
    Quote Originally Posted by Ladd View Post
    thanks, both going out today....
    Anyone else get theirs yet. Interested to know what's fitting for folks....
    Nov 2015
    Michigan, USA
    Received mine yesterday, they are matched to thread spec as expected. Thanks Mick.
    Aluminum Bronze and Tellurium Copper, hand tapped so my host should be fine for any made to proper spec.
    picture didn't show!
    Nov 2015
    Michigan, USA
    Weird, wonder if this helps any.
    Jan 2014
    Louisiana
    Raw Ti fit my cerekote just fine.
    Thanks Mick, you rock!
