Hey guys, I work in aircraft production and have to spend quite a lot of time inside the wing tanks, the torches we're provided with are bayco nightsticks (http://www.emergencyequipmentnews.net/2008/06/14/bayco-nightstick-new-models/ the second one on this page)
And they're near useless.
The bayco claims to be 400 lumens in flood mode (the four leds on the side of the tube) ideally i need something at least twice as bright.
The space working inside is kinda the same size as the airconditioning vents you always see people crawling through in movies for some idea of the situation the torch will be used in. So i dont really need a long throw just a good clear wide flood for inside the tank.
The tube with the leds on the side works very well as a design as it alows the torch to be laid between the stringers and aimed at the place youre working in so going to keep that kind of shape, maybe a pipe the leds out one side with caps either end with octagonal plastic/rubber bumpers so it can be angled at a good range of angles and not roll.
The other big requirement is battery life, i need it to last a solid 12 hours. (The bayco lasts about 3 before needing a new battery, which are all screwed from abuse).
Also due to the werid angles you often find yourself to relative to the torch I'd prefer not to use PWM to control the brightness because the flicker can drive you mad when its at the extremes of peripheral vision. (We have some cfl lead lamps and thier flicker is infuriating)
I'm reasonably competent at making things both mechanical and electrical but looking at LEDs there just such a wide range that i have no idea where to begin.
I was hoping you guys could help me work out what type and number of LEDs would be best (more dimmer leds better than fewer bright ones?) Along with the kind of driver and batteries that could give the kind of life i need.
Optics are something i do have zero knowledge of so advice there would be great, but im thinking as its a short range flood they wont be that important.
Any advice you could give would be a great help
