slackercruster
I was told I can buy a infrared filter for a flashlight and a set of glasses to go with the filter to see in the dark. Is that how it works? Can you see things at a distance like white light flashlights allow?
For close use (within a few feet or so) any incandescent light with an infrared filter will only emit infrared (and maybe a little deep red, depending on the filter). As Dr. Mario stated, you will need an infrared viewer to see the results. An infrared filter will perform very poorly or not at all on an LED emitter, because LEDs emit virtually no infrared, except for those he mentioned which are designed solely to emit infrared. That is why one sees mostly incandescent bulbs in a lot of military lights.Thanks, sounds complex. I was looking for a small infrared light like a Surefire size for pocket use.
Any infrared gurus on here, is there any kind of simple sensor or indicator that will give a visible reaction to an infrared beam?
