Hello everyone,
I searched the internet for a place I could ask this question and this seems like the place that may give me the answer.
What I want to do is cure some automotive clear coat using a uv light. It's a two part clear.
I'd like to add a photoinitiator to it but not sure where to buy yet. Maybe someone has a suggestion?
But, that wasn't my original question.
What I have is a led panel that is typically used for clubs. These are the specs:
Is there a some kind of film I can place over the front panel to decrease the 405nm down to 365nm? I was even thinking liquid sunscreen as a last resort. Don't know if it will work but it's suppose to block uv rays.
Thanks!
- Light Source: 192 LEDs (UV) 0.25 W (20 mA), 100,000 hours life expectancy
- Power Linking: 43 units @ 120 V; 74 units @ 230 V
- Input Voltage: 100 to 240 VAC, 50/60 Hz (auto-ranging)
- Power and Current: 12 W, 0.1 A @ 120 V, 60 Hz
11 W, 0.1 A @ 230 V, 50 Hz - Weight: 4.9 lb (2.2 kg)
- Dimensions: 14 x 9.8 x 6.5 in (356 x 248 x 165 mm)
- Approvals: CE
- Optional Controllers: IRC-6
- Wavelength: 405 nm
Thanks!
