ameli0rate
- Joined
- Jan 26, 2014
- Messages
- 53
My car SHOULD take the 6418 bulbs in the dome/map lights if I am not completely mistaken. The manual lists all bulbs but those.
This is mostly a cosmetic issue as the heat doesn't seem to deform the plastic in the dome lights yet. I had a few cheap imported eBay special festoon LEDs that I put in the car (2006 Volvo V70, 36mm festoons in the dome lights if I recall right, I think it's 40mm in the footwells) with a parallel resistor. The light was better1 with a little more brightness in the car and with the resistors installed they didn't glow while the car was awake and even theater dimming worked just fine.
After about a year, they started blinking and flickering and then finally died.
So.. this looks like a worthy bulb if it's not too wide for my housings;
http://www.jmgoods.co.uk/acatalog/37mm-LED-Festoon-Bulb--10-watt-equivalent.html#SID=24
eBay shows listings for the "Sylvania Premium" 6418s between $6-$10 each. Claimed compatibility with 6461 and DE3425 bulbs (any of those two model numbers better/brighter/stronger than 6418s?).
There are also the "Sylvania ZEVO" bulbs, though I don't know what the difference are between ZEVO and "Premium".
These bulbs have a frosted covers and what looks like a heat sink on the back. Official-looking packaging too, to my untrained eye.
My question is if these are good quality bulbs that could be expected to last in the car (Texas summer heat, occasional winter cold, vibration and 80's glam rock) or if I should pass on them.
I'm *still* extremely glad to have listened to Alaric & Virgil about the OEM headlights on the same car! I ended up with a set of European OEMs that are leaps and bounds better1 than the old, faded, 110K mile OEM lights I replaced: http://www.robdiesel.com/wordpress/?p=24
*1 - Subjectively speaking. I'm no expert.
PS.
I used the Sylvania LEDriving 194 bulbs in the puddle lights under my exterior rear-views. Excellent and long-lasting bulbs with a lot of light. Am I breaking the "no LED bulbs outside" laws with that given that they're not a safety related light? Oddly enough they ONLY come on with a separate button on the remote, not at lock/unlock of the car, or follow-me-home lights. When I hit the "UFO" button, the puddles, tail lights and city lights up front come on. Weird.
If this is illegal, this question is for a friend. Or hypothetical. :naughty:
PS.
