Sadden
- Joined
- Mar 14, 2015
- Messages
- 262
So i did the H11-H9 conversion on my Peterbilt, while it was an upgrade, it didnt wow me.. I took some time and read the instructions for our optical headlamp aligner, and spent the time to get everything aimed to the best of my ability. However modifying the H9 is a bit of a pain, and will become a monthly chore given the bulb life.
The other problem I have is that the lows really lack hotspot intensity, very poor performance in that department (at least subjectively). I havent looked into the OEM wiring yet, however i am starting to suspect it is poor. I dont want to go to a relay harness, but I might take a look and see how hard it would be to swap out the oem cables between the relay and the bulbs to something a little heavier gauge. After I take the time to properly measure voltage drop.
So now I would like to explore auxiliary lowbeam options. That way i can put a midgrade H11 in the existing lowbeam. So heres my must haves
-No LEDs, icing is too much of a problem up here, also CRI is too low given our inclement weather...
-Easy to mount on pre-existing bumper tabs
-Open to BI output, but not interested in dual filament bulbs
-Must readily accept high output bulbs , 9012, 9011, h9, d2s etc
Also what would a quality midgrade H11 choice be? I dont want to drop back down to LongLife bulbs, but dont want to be replacing these every month either, something more middle of the road would be ideal.
