Benediction
With NiMH batteries (yes I know, for those Lithium people...NiMH very primitive. Take some Lithium salts )
How low do most devices discharge them for your usage. In a flashlight you would decide it is too dim, other devices would refuse to power on, whatever criteria you choose for "discharged".
Which is to say for those of you with smart chargers, how many volts remain if you put them in the charger after draining them in a flashlight or whatever use you have for the NiMH batteries.
Most chargers default to auto-charging, and volts output will only be accurate under load, so perhaps put the charger in discharge mode to find out (charger will usually proceed to charge, or you can put it back with a few button presses).
Please post with
Name of Device: remaining Volts under load
Directional Microphone 1.02, 1.00 and 1.01v remaining (uses 3 batteries)
Thanks in advance.
Please post with
Thanks in advance.
