RMSK, Inc.
Results 1 to 15 of 15
Thread: Test/review of Charger GyrFalcon All-44 (Enova)
    HKJ's Avatar
    Mar 2008
    Copenhagen, Denmark
    Default Test/review of Charger GyrFalcon All-44 (Enova)
    Enova makes many different chargers, this time I have got a 4 slot version of their largest universal charger (8 slot). The charger uses the same design, but there is some small changes.
    I got the charger in a cardboard box with specification on it.
    In the box was the charger, a power supply, a instruction sheet, the warranty card, two spacers and two terminal extensions.
    The DC input is the usual barrel connector and it is rated for 12V input.
    The full user interface with 4 readouts and 6 buttons, one for each slot and two special buttons. All buttons has a leds in them.
    The slot buttons will show a blue led while charging and a red led when done.
    The display has many elements on it, because the charger can handle many types of cells.
    Depending on mode not all the elements are used.
    First image is manual mode and second image is automatic mode (No block or marker for VV line). Hold down Fn and CV for some seconds to change mode.
    In automatic mode the slot buttons is only used to change current, selection of voltage and starting is automatic.
    In manual mode some more button presses are needed:
    Start a slot (Method 1):
    Press button for slot to select it.
    Press button for slot again to select voltage.
    Press CV to select current setting.
    Press button for slot to select current.
    Press CV to select voltage setting again.
    Hold button for slot down to start charging.
    Start a slot (Method 2):
    The above methods are rather long if you want to charge many cells, the charger has some shortcuts to handle that:
    Hold button for charging slot down and tap button for other channel will copy the settings tio all slot in between and start charging on these channels.
    Hold Fn down and press CV will select 1A and 4.2V charge voltage for all idle slots, pressing multiple times on CV will change voltage.
    These short-cuts means that charging any number of (4.2V) 18650, 26650, 32650 can be started by holding Fn down and tapping once on CV.
    Charging any number of AA can be starting by holding Fn down and tapping CV twice.
    Here the charger is working with a couple of different cell, each with its own setting.
    The C.A line shows selected current and is also used to select current when the ">>" marking is at this line.
    The V.V line shows selected charge voltage and is also used to the select voltage when the ">>" marker is flashing at this line.
    The battery icon is animated when the charger is charging.
    The sliders work very smooth and can handle from 32.0mm to 72mm, up to 26mm cells can be placed in each slot and it is possible to use 32mm cells in the slots, but not in slots next to each other.
    Using this accessory 32650 cell can be charged.
    Using the spacer shorter cells can be charged, each spacer is about 8mm.
    The charger can handle 72 mm long batteries including flat top cells.
    With 10180 cell the 100mA charge current is on the high side, but because most 10180 are high current cell it will usual be acceptable.
    Measurements on charger
    • Power consumption when idle is 0.7 watt
    • Will discharge a LiIon with 0.1mA when not powered.
    • Will discharge a LiIon with 0.7mA when not charging.
    • Will discharge a NiMH with 0.03mA when not powered.
    • Will not charge at 0 volt.
    • NiMH charging start at 0.6 volt with selected current.
    • LiIon charging start at 0.6 volt with a 50mA.
    • LiIon current will drop to 20mA as voltage increases, at 3.0V selected current will be used.
    • Meter starts working at 0.7 volt.
    • Meter is within 0.01 volt.
    • Meter stops updating when battery is full.
    • Meter will not reduce reading.
    • Charger will restart silent if LiIon battery voltage drops below 4.05 volt.
    • Power cycling and insertion of a battery requires button press to start charging in manual mode.
    • Power cycling and insertion of a battery will automatic select NIMH/LiIon and start charging in automatic mode.
    • Charger has a time limit of 10 hours, except NiMH at 1A where it is 5 hours.
    Charging 4.20V LiIon cells
    A good CC/CV charge curve with about 80mA termination current.
    All the other slots look the same, but there is a small variation in charge voltage and a bit larger variation in charge current, but neither is a problem.
    Different capacity means changes in charge time.
    This old cell reaches CV phase fairly fast.
    The 0.5A current is fine for 14500/18350 and other cells with 0.6Ah to about 1.3Ah and it works fine.
    Here I tried lowest charge current, it works fine and has a low termination current (good).
    The charger can charge 4 cells with 1A simultaneous.
    Doing this requires about 2A from the power supply.
    M1: 39,5C, M2: 44,3C, M3: 44,3C, M4: 41,5C, M5: 44,1C, M6: 41,7C, HS1: 74,1C
    The charger and batteries are about 44C warm and inside the charger there is a hot electronic part, both are acceptable.
    The charger will start automatic after about 1.5 to 2 seconds.
    It is possible to change current during charge. In automatic mode just press the slot button. In manual mode first press the slot button, then the CV button, now the slot button can be used to change current.
    Charging 4.35V LiIon cells
    The charger supports both 4.30V and 4.35V cells, I only did a test with 4.35V and it looks fine.
    Charging 3.6V LiFePO4 cells
    The charger works fine with LiFePO4 cells. The charger uses a low current until the cell reaches 3V, then it will switch to selected current. For fully discharged LiFePO4 cells it can mean that charging takes an extra hour.
    Charging NiMH cells
    In manual mode it is possible to start a NiMH cell on a LiIon program, but it is not dangerous. Charge current will be low and the charger will stop after a few hours.
    The NiMH charging stops on -dv/dt and looks fine.
    On all slots, there is a small difference in current, but that is not important.
    The 3 high capacity cells are also terminated perfectly.
    No problem with an AAA cell.
    Even at 0.1A the charger will terminate. This test would terminate earlier in the release version due to the 10 hours timeout (This timeout is missing in my test version).
    As usual -dv/dt is some time to terminate on a full cell, about 10 minutes is a fairly good time.
    The charger has no problems with charging 4 cells at full current.
    With NiMH it uses about 1A from 12 volt.
    M1: 46,0C, M2: 50,3C, M3: 51,0C, M4: 47,1C, M5: 41,4C, M6: 65,4C, HS1: 77,9C
    The charger heats the NiMH cells and the temperature is at the limit.
    Starting is exactly the same as for LiIon.
    With NiMH the charger stops every 20 seconds to check the voltage of the cells.
    Current change also works the same as for LiIon.
    Testing the transformer with 2830 volt and 4242 volt between mains and low volt side, did not show any safety problems.
    Conclusion
    In automatic mode the charger works like any other good charger and will charge 4.2V LiIon and NiMH cells with a default current of 1A (A press on a button will change the current). Switching to manual mode the charger can charge most round cells on the market, at the cost of some more button presses.
    I do not like the slot extension, I doubt I can find them when I need them. A longer bar on the plus side would have been much better (This is only relevant if you need to charger 32xxx cells).
    I will rated this charger as a very good charger, especially if you have many different types of cells.
    Notes
    The charger was supplied by Enova for review.
    Here is an explanation on how I did the above charge curves: How do I test a charger
    My website with battery, charger, usb reviews, comparisons & information: https://lygte-info.dk/
    Latest addition is multimeter reviews
    Flashaholic* MAD777's Avatar
    Jul 2015
    South Florida
    Default Re: Test/review of Charger GyrFalcon All-44 (Enova)
    Another great review, HKJ.
    I have the 8-bay version of this charger, which I am very happy with. I bought it after reading your review of that charger.
    Nov 2016
    Slovenia
    Thank you for another excellent review.
    I am a bit confused about the supported battery type table, usually you had only 2 types of ICR battery, the 3.6/3.7V that charge to 4.20V and the 3.75/3.80V that charge to 4.35V. Now there is another 3.7V listed that charge to 4.30V.
    Am I missing something? Or to put in another way, how do you know which 3.7V battery to charge to 4.30V and which to 4.35V?
    HKJ's Avatar
    Mar 2008
    Copenhagen, Denmark
    Quote Originally Posted by Trango View Post
    You need the datasheets for the batteries, there it list the charger voltage.
    Some cells with 4.3 volt charge:
    http://lygte-info.dk/review/batterie...nge)%20UK.html
    http://lygte-info.dk/review/batterie...ple)%20UK.html
    Nov 2016
    Slovenia
    Didn't know that, thank you.
    And I presume that if your charger has only 4.20V and 4.35V is better to charge them at 4.20V and lose some mAh than to charge them at 4.35V.
    HKJ's Avatar
    Mar 2008
    Copenhagen, Denmark
    It will give longer lifetime, but if the 4.35V charger is slightly low on voltage it will be within the 4.3V specification.
    Jan 2015
    Scotland
    Thank you for the review, HKJ!
    Like MAD777, I bought the All-88 after reading your review of it, and it's a really nice charger. I'm seriously considering buying an All-44 as well, to use on a desk where I'm a bit low on space. I'd even be interested in an "All-22" if such a charger existed
    As someone who is legally blind, I love the fact that the All-88 requires a manual button press to start charging, because I can take as long as I need to choose the settings and make sure I've got them right.
    If you set the All-44 to manual mode, does it stay in manual mode after it's been power cycled, or does it revert to automatic mode?
    Phlogiston is the main constituent of Magic Smoke.
    Dec 2015
    Elk Mound, WI USA
    Thanks for the great review HKJ. I expected this and ordered one last week.
    Top 5=> MX30L4Cvn xpl HI 4000K, SD26vn 219c, T6vn xpl pdt, U21vn xpl pdt, D25Cvn, BLF GT, BLF Q8, TN30vn35#2, SC63w, K40Lvn, K40Mvn, U21vn#1, MK35vn, TN30vn50, X7vn, X45vn, EC50vn, EC60vn, MK35vn, ToolvnCu, T21vn, U11vn, TX25Cvn, S200C2vn & C22Cvn. Charger: SkyRC
    HKJ's Avatar
    Mar 2008
    Copenhagen, Denmark
    Quote Originally Posted by Phlogiston View Post
    It remembers last selected mode, even when power is cycled.
    Jan 2015
    Scotland
    Perfect. Thank you very much
    Thank you for the great review, HKJ.
    Unenlightened
    May 2012
    What an awesome review! I got here via your site, HKJ, with all the excellent reviews! thanks for sharing them!
    I am posting to ask if anyone know of US based vendors that carry this model.
    Or if it is labeled as other brand names.
    I searched for both GyrFalcon and Enova, but the scarce places i found selling either the All-44 or the All-88 look really shady with very low mentions on this forum. ...and with very long delivery times.
    Thanks!
    Flashaholic* Rexlion's Avatar
    May 2009
    Tulsa
    I just bought this Enova Gyrfalcon All-44 charger. Your reviews helped immensely in choosing one that could do everything I wanted.
    However, when it came and I started trying to set a slot to charge my LiFePO4, I had to struggle a while with it. For one thing, I could not figure out why the arrows would not move to the V.V line. And I did not see when the cell should be inserted in the slot. The user manual that comes with the charger is nearly worthless, and even your directions did not fully sink into my brain. So I have written my own version of
    "how to start charging in one slot using manual (advanced) mode":
    1. Determine if its in general mode or advanced mode.
    How to tell: General mode wont allow arrows next to V.V, advanced mode will have them at V.V from the start.
    To switch between modes, hold down Fn and CV for 5 seconds
    2. Set up a slot using Advanced Mode:
    Press a slot button; time will flash
    Press slot again as many times as needed to adjust voltage (watch light bar move between 1.5, 3.6, 4.2, etc.)
    Press CV to lock in that voltage; arrows move to C.A.
    Press slot as many times as needed to adjust current
    Press CV to lock in that current
    Insert cell to be charged,
    and then hold down slot button until battery icon begins to flash.
    This slot is now charging.
    This is what worked for me, anyhow. I hope this restatement of the sequence helps anyone else who has trouble getting started in advanced mode with the All-44 or its twin, the All-88 charger. I'm the type who needs to see directions laid out as 'step 1,' 'step 2,' etc.
    ___________________________________
    ==A 3D photography nut, turned flashaholic==
    Aug 2012
    Arkansas, USA
    Is this simple to use? I won't be touching advanced modes, but would like to charge my LiON and my enloops on same charger. Can i just put them in and forget with this one?
    HKJ's Avatar
    Mar 2008
    Copenhagen, Denmark
    Quote Originally Posted by ateupwithgolf View Post
    "Simple to use" is a very relative expression.
    For me it is simple to use, but I have tried a few chargers. You may find it very complicated.
    The best advice is to read my notes about how it works (In the first part of the review), if you think that is simple enough, you are good to go.
    The new generation of GyrFalcon charger starts in a simple mode, where they can just charger NiMH and 4.2V LiIon with automatic selection, i.e. you do not have to worry about all the possibilities in the charger, except if you have other type of batteries.
