I am having trouble finding a headlight assembly for my mom's 2004 Mitsubishi Galant GTS. All other models of galant use a headlight assembly with a 9007 bulb. The GTS uses an assembly with a 9005 and a 9006. The only option I can find is direct from dealer for the GTS assembly. To keep from spending over $400 I was wanting to run the high beam and low beam circuits into one 9007 plug. I have found wiring diagrams, and I have experience soldering, so making the connections is not the problem. I was wandering if anyone knew of a harness that was pre-made which I could purchase to save the time of having to make it. I also want to know if this is even something that can be done due to different power draw, and output.
Thanks,
D.J.
Thanks,
D.J.
