HDS Systems
Results 1 to 9 of 9
Thread: 3AA mini mag how to remove LED module?
    Default 3AA mini mag how to remove LED module?
    Note THREE AA. Do they make this anymore? Had corroded batteries & wanted to remove the LED module before soaking. Tried pulling from front, and the black sleeve came off. But it won't come out the front, & gets stuck a couple inches backwards, which seems odd. And the LED came off -- no solder !!! just some yellowish stuff, mostly beneath it (heat conductive paste all dried out ???) and two metal "ears."
    If I get this out, any drop-ins to improve it? Maybe there is space for 2x 14440s?
    There should be a sticky with the contact information for battery makers when we want to make a claim. Phone for Duracell anyone?
    Mar 2013
    Southern Ontario
    Default Re: 3AA mini mag how to remove LED module?
    Try this
    http://budgetlightforum.com/node/1642
    Yours being a 3 cell is even better. 3 NIMHs are the same voltage as a single lithium ion cell
    I don't think Duracell will help you. Alkaline cells just leak. Why I don't use them
    This damn thing is still lying around. Went to soak it in baking soda & wife is out of it.
    Still can't get the black plastic LED holder out of the tube. won't fall out either end. What's up with that?
    Links to P60 modules that will work with the 3 cell voltage?
    Jul 2014
    Kansas
    The led module is bell shaped, it's not gonna come out the front. Duracell may be helpful.
    You mentioned 14440s, keep in mind 14500s are the same size as AAs.
    Quote Originally Posted by vicv View Post
    Try this
    Their link to suitable drop-in modules is dead.
    Anyway, want an up to date module.
    Is there a size & fit spec other than P1 (?) that I need to look for? 3 cells would be 4.5 v for AA or a bit more for 14440?
    Maybe need a different reflector, glass lens... etc?
    Would be fun to have a green LED with lots of lumens.
    Flashaholic* kosPap's Avatar
    Mar 2007
    Naoussa Greece
    the drop-ins are generic ones. see fasttech and solarforce-sales for many of...
    Quote Originally Posted by kosPap View Post
    Solarforceflashlight-Sales.com domain name expired
    Oh, I guess I need a tail switch to make a P60 module work since its not designed for front-twist operation like the Mag ?
    Jul 2014
    Kansas
    Not necessarily, I used a diy led p60 drop in in a mini mag. It worked great. Reflectorless xhp50, literally lit up a whole room.
