DaFABRICATA
This titanium light has 36 inset Superconductor discs added around the perimeter of the body. Each disc was cut from a rod and press fitted (actually hammered :laughing into each milled pocket and then cut down on the lathe and finish sanded by hand. There's over 10 hours in fitting the superconductor accents alone. All work is done manually on my lathe and mill.
The light is still a work in progress. The holes need to be drilled/tapped for the Okluma pocket clip and a proper light engine still needs to be made. I may also remake the bezel.
The body accepts McGizmo and Surefire E-series heads and has a McClicky switch in the tail.
The head accepts McGizmo/Aleph light engines and uses an Zebralight reflector.
A mule type head may also be made for it before I post it up for sale, giving the new owner the option of throw or flood by swapping heads.:thumbsup:
