raggie33
*the raggedier*
- Joined
- Aug 11, 2003
- Messages
- 13,501
i got the 5th gen aa. that have the 10 year shelf life but man o man compared to akilines in my streamlight seige the run time is aweful
this is the 1 i got i think its the same as you posted its a awesume light it is very small and floatsMust be an "Streamlight 44941 Siege AA Lantern, Coyote" if it takes 3x AA cells.
Are the AA NiMh cells fully charged? or is the lower voltage is making the low battery warning come on early?
https://www.amazon.com/dp/B00OW5AK22/?tag=cpf0b6-20
John.
i hope thats it between the batterys and chargers i bought i spent a lot. and i hate to waste moneyMy guess is the alki cells are soon dropping due to sag and your probably getting quite a bit less light out although not that easy to tell by eye. The loops have a flatter discharge and will hold a higher voltage over the alki cells. So just an example plucked, the loops may be giving you 150lm or so after 10m of being on.............may continue close to that for a couple of hours. The alki cells may drop pretty quick and be putting out 60-80lm and decreasing ..................again an example.
Its not a wate raggie, you have many many 100's of charges...............once your alki cells are done, they are done for good! Even if they take 4 re-charges to match the alki cells, they will still save money down the line.
bet thats it i just recalled my voltmeter has a light meter built in, its pretty cool also has a sound meter3 x AA alkalines won't run a 200 lumen light for 7 hours at constant output. It is most likely either dimming unnoticed over that time, or is set on low. The subtle nature of the dimming will surprise you. I have a cheap headlamp that I can use for hours without noticing any change in brightness. Eventually I start to think maybe it has dimmed a bit, so I swap batteries and am surprised at how much brighter it suddenly is.
2:25 sounds a bit short for Eneloops, however. I tried a search and managed to find a runtime measurement on your lantern using Eneloops where it got about 3 hours of fairly consistent output before starting to dim significantly, ending around the 10% mark a little shy of 4 hours:
http://www.candlepowerforums.com/vb...al-Review-Streamlight-SIEGE-AA-Lantern-(3xAA)
Be aware that although Eneloops are sold "precharged," they're actually usually around 70% of full charge from the factory. That may explain your results if you didn't charge them up new.
