Klarus
Results 1 to 2 of 2
Thread: Test/review of Vbatty IMR18650 3000mAh V30 (Blue-gold)
    HKJ's Avatar
    Mar 2008
    Copenhagen, Denmark
    Default Test/review of Vbatty IMR18650 3000mAh V30 (Blue-gold)
    Official specifications:
    • Brand: Vbatty
    • Size: 18650
    • Chemistry: IMR
    • Nominal Capacity: 3000mAh
    • Nominal Voltage: 3.7V
    • Discharge: 30A Continuous, Rated 40A Max Pulse by Vbatty
    • Positive: Flat
    • Rechargeable: Yes
    • Dimensions: 18.23mm x 65.02mm
    • Weight: 46g
    This is a high capacity and high current battery.
    The discharge curves has good tracking and capacity only drops slowly with load. The battery has trouble at 30A due to heat.
    The battery will get warm at high current.
    At 20A it was very close to a termination due to temperature.
    At 30A I had to stop due to temperature. The battery reached 86°C after I terminated.
    Conclusion
    This battery has very good performance for both capacity and current.
    Notes and links
    The batteries was supplied by Shenzhen Vbatty for review.
    How is the test done and how to read the charts
    How is a protected LiIon battery constructed
    More about button top and flat top batteries
    Compare to 18650 and other batteries
    My website with battery, charger, usb reviews, comparisons & information: https://lygte-info.dk/
    Latest addition is multimeter reviews
    Banned
    Aug 2013
    Valley Forge, Pa.
    Default Re: Test/review of Vbatty IMR18650 3000mAh V30 (Blue-gold)
    Thanks for the review!
    I will have to compare these to the top IMR batteries!,,,,,Using your comparator of course.
    EDIT: I am impressed.In terms of Voltage sag,,,,,,,,,, It is slightly better than LG HG2, Basically even w/ the 30Q and ONLY bettered slightly by the VTC6!
    I am taking a wild guess and saying that it is using a 30Q cell. Throughout different voltages the curves are basically identical.
