Jetbeam
Results 1 to 2 of 2
Thread: Manker MK35 Cree XHP35 HI 4*18650 2550lumens 1420meters Super Thrower is Releasing
    Buttrock Manker MK35 Cree XHP35 HI 4*18650 2550lumens 1420meters Super Thrower is Releasing
    Key Features:
    1. Cree XHP35 High Intensity LED Max Output 2550lumens, Max Beam Distance 1420 meters with 4 18650 batteries.
    2. Classical Manker interface gives different output levels and functions and a lock out function help to avoiding accidental turned on.
    3. Updated Manker side swtich button, solid and more beautiful, retained Manker classical dragon breath function
    4. Robust body with a stainless steel bezel make MK35 can be used for security popurse
    5. An ideal flashlight for search&rescue, hunting and law-enforcement etc.
    Specifications:
    1.Emitter: Cree XHP35 HI (CW and NW for your choices)
    2.Maximum output: 2550lumens for CW version (NW version output is about 20% less than CW)
    3.Maximum beam intensity: 504100 CD Maximum beam distance: 1420 meters
    4.Working voltage: 11.2V-16.8V (Over discharge protection)
    5.Driver: Most efficiency constant current circuit
    6. Material: Aircraft-grade aluminum body
    7. Surface treatment: Premium Type III hard-anodized anti-abrasive finish
    8. Lens: Toughened ultra-clear glass lens with anti-reflective coating
    9. Water proof: IPX-8 (2 meters under water)
    10. Impact resistance: 1.5 meters
    11. Tail stand
    Dimensions:
    Length 188mm, Head Diameter 86mm
    Weight 675g (Without battery)
    Accessories: O-ring *1, Lanyard*1, User manual*1 Holster*1
    Output and runtime:
    Moonlight: 0.1-5lumens 1500hours, Low: 47lumes 76hours
    Medium 1: 136lumens 21hours , Medium 2: 700lumens 7hours, High: 1600lumens 2.5hours , Turbo: 2550lumens(2550lumens last on 15 minutes then stepdown to 1600lumens) 2.5hours, Strobe: 2550lumens
    Batteries: MK35 use 4 18650 batteries
    Side switch battery indicator:
    1. Blue: More than 75%
    2. Purple: 50%
    3. Red: Less than 20%
    Operation:
    Please refer to the image:
    Lock out:
    One click-Double-Triple from any mode to lock out the flashlight.(Only the battery indicator works when lock out)
    Engineering Mode(Choose output level for Moonlight mode):
    Long press for off and still hold on, the side button battery indicator will turn on and then quick click for 4 times to get access to engineering mode. One click to check different level and long press to make your final choice.
    More details please visit http://www.mankerlight.com/manker-mk...ed-flashlight/
    Flashaholic* Tac Gunner's Avatar
    Oct 2012
    Bluegrass Region of KY
    Default Re: Manker MK35 Cree XHP35 HI 4*18650 2550lumens 1420meters Super Thrower is Releasi
    Nice looking light
    Reliability, NW and moonlight mode, the most important factors in a light
