Test/review of Keeppower IMR18650 NH1835 3500mAh (Black) 2016
HKJ
Copenhagen, Denmark
[size=+3]Keeppower IMR18650 NH1835 3500mAh (Black) 2016[/size]
Official specifications:
  • Nominal capacity: 3500mAh
  • Minimum capacity: 3400mAh
  • Nominal voltage: 3.70V
  • Charge voltage: 4.20V 0/-0.05V
  • Standard discharge cut-off: 2.50V
  • Standard charge current: 1000mA
  • Charge current cut-off: 50mA
  • Max. Constant discharge current: 10A
  • Max. Pulse discharge current: 20A
The discharge curves looks very good with nice tracking, except the 20A curve, the battery did blow a fuse during that discharge.
This also means this test will be missing a few curves.
[size=+3]Conclusion[/size]
The battery is very good, but cannot sustain 20A discharge, this matches the specifications.
[size=+3]Notes and links[/size]
The batteries was supplied by Keeppower for review.
How is the test done and how to read the charts
How is a protected LiIon battery constructed
More about button top and flat top batteries
Compare to 18650 and other batteries
Colorado_Cliff
I appreciate your test and just purchased 4 of these batteries after seeing how these perform.
