RMSK, Inc.
Page 1 of 9 12345678 ... LastLast
Results 1 to 30 of 269
Thread: Opus BT-C3100 2.2-Comparison-New and Exchanged.
    Banned
    Aug 2013
    Valley Forge, Pa.
    Thumbs up Opus BT-C3100 2.2-Comparison-New and Exchanged.
    I CHANGED THE NAME OF THE THREAD! YOU WILL SEE WHY AS IT PROGRESSES!
    OK,,,,,,,I have sort of been on a Charger binge. More contemplation than actual purchasing. Although I have Two new ones.
    I have gone back and forth with the newer chargers with this so called fancy technology and a few that I already have w/ Two or Three year old technology.I have come to the conclusion that I prefer my slightly older technology to the more recent chargers with more functions.
    I had my eyes on the Opus BT-C3100 2.2,Liitokala Engineer Lii-500 and most recently the Xtar Dragon VP4. I submerged myself with as much information as my old brain could absorb! I asked questions, read reviews and measured the pros/cons.
    There are several that test Internal resistance, get the capacity by charge/discharge/charge[that sounds time consuming to me!], show the actual charging current[live] and several others.
    It got me thinking that for me, simplification is all I need and what works best. Below are the ONLY things I really need/want in a charger:
    "THE SIMPLE SEVEN"
    1.MUST GIVE A FULL CHARGE-4.20V [NOT MANY CHARGERS SEEM TO DO THAT TODAY].
    2.RELIABLE
    3.DURABLE
    4.HAVE AT LEAST 2 CHARGE CURRENTS, PREFERABLY 3.
    5.HAVE A VOLTAGE DISPLAY ALONG WITH EITHER A CHARGE PERCENTAGE AND/OR A BATTERY W/ BARS INDICATOR!
    6.CAN CHARGE A 3400mah 18650 @ 3.60V IN 2.5 HOURS OR LESS!
    7.ABLE TO CHARGE MULTIPLE SIZE L.ION AND Ni-MH.
    I have about Ten[10] chargers if I go back to the beginning! I use Four[4] or Five[5] of them.
    1.EFEST LUC V4 [1]
    2.KEEEPPOWER L2-[1]
    3.FENIX ARE-C2 [3]
    4.FENIX ARE-C2+[1]
    My Fenix ARE-C2 is the "only" One out of those Four[4] that can do "THE SIMPLE SEVEN"!
    I do not need to check the Ir and true capacity. I can tell when my batteries are degrading SIMPLY by actual use and using my DMM before charge, after charge and after resting awhile! Once I notice a battery that has a resting voltage of 4.08 to 4.11V then it is time to recycle them or save them for emergencies!
    The charger just needs to have the "SIMPLE SEVEN". Charge them, put them in my Modded trail torches and repeat the process with no worries!
    If not, I am the kind of guy that would obsess about ALL those tests, keep track of all the batteries and how they fared! In the mean time Poor CAPO would be deprived! He would get fat, I would get fat and that is that!
    I will say that out of ALL of my chargers I like the display of the L2 the best.
    As you can see it has charge rate/% of charge/voltage/time elapsed and battery progress w/bars! 5 pieces of info in such a small LCD Screen!
    If it gave a Full charge[only 4.15/4.16], was a little faster and had Four bays,,it would be my favorite,,,,,I still like the little guy!
    HKJ's Avatar
    Mar 2008
    Copenhagen, Denmark
    Default Re: BACK TO BASICS-SIMPLE,EFFICIENT AND DURABLE!
    Quote Originally Posted by Capolini View Post
    Look for chargers that do not terminate the charge or charge to 4.25 volt, they are basically the only ones giving full 4.20 volt.
    All chargers following the LiIon charge guidelines will give a lower voltage.
    My website with battery, charger, usb reviews, comparisons & information: https://lygte-info.dk/
    Latest addition is multimeter reviews
    Flashaholic* hiuintahs's Avatar
    Sep 2006
    Utah
    Right. And to add reasoning as to why that is so......... The connection impedance between the battery and the control electronics is a small voltage drop. So if the electronics is designed such that its only putting out 4.20v in the CV charging phase, then you get a smaller than 4.20v full charge at the battery. The way to mitigate that to a smaller difference is to charge at a lower rate. Thus the voltage drop through the battery connection medium is smaller. I find myself charging at a full one amp on the 18650 which terminates at 100mA and then doing it again at 250mA charge rate which terminates at 25mA. But the improvement is only a couple of tenths of a volt.
    Also I found that the chargers that have the spring loaded contacts on the common side of the battery has quite an impedance drop from battery neg terminal through the spring and then back to circuit electronics ground. And that will contribute to a couple of tenths of voltage drop. So the only way to compensate for that is to put higher than 4.20v when in CV mode as HKJ has implied. But I don't think there is a lot of difference in charge capacity between a battery that attains 4.20v vs 4.18v from the charge process.
    Banned
    Aug 2013
    Valley Forge, Pa.
    I guess my Fenix is an exception then!! It never charges past 4.22V and that is usually w/ IMR batteries.When it charges to 4.20V, the resting voltage is usually 4.17/18v at least. I have had brand new VTC6/30Q retain a 4.20V after a few days!
    EDIT: This is from "stephenk" from BLF regarding the Xtar Dragon VP4
    My XTAR DRAGON VP4 Plus charges to 4.19V.
    I know you did that review. I do not recall if you mentioned the voltage at termination?That is sufficient to me and passes my test as far as ending voltage!
    Feb 2006
    USA
    My opinion is the XTAR VP2 is the best [basic, simple, efficient, and durable] charger for the money.
    An absolute steal for ~$27 shipped to your door.
    Banned
    Aug 2013
    Valley Forge, Pa.
    Quote Originally Posted by seery View Post
    That is similar to my K'power L2,,,,,,,,,,,,Both ONLY have 2 slots!
    HKJ's Avatar
    Mar 2008
    Copenhagen, Denmark
    "Do not terminate" is not the same as over voltage, there is some chargers that never turns the current off, but keeps 4.2 volt. Last one I tested of the type was Miboxer: http://lygte-info.dk/review/Review%2...20C4%20UK.html (They will fix it in their next charger).
    More about charging: http://lygte-info.dk/info/BatteryCharge4.2V%20UK.html
    Banned
    Aug 2013
    Valley Forge, Pa.
    iirc you never tested the ARE-C2, only the C1.
    HKJ's Avatar
    Mar 2008
    Copenhagen, Denmark
    Correct, Fenix did not send me one and because I tested another charger that looked like it, I did not really want to buy it.
    http://lygte-info.dk/review/Review%2...CC-4%20UK.html
    Banned
    Aug 2013
    Valley Forge, Pa.
    Thanks for the info. I checked out your links. I knew some of it and I understand most of it!
    It is a Psychological thing[4.20v]!!
    I know if a new/relatively new battery comes out of the charger @ 4.14/15v it makes no difference at all as far as run time.
    With that said I still like seeing a 4.20 charge! I just got done charging my VTC6 in my ARE-C2[When I have single cells they usually go in my K'Power L2]. One VTC6 Came out @ 4.22v The other at 4.21v,they are 6 months old. they will not settle too much. They would be 4.18/19V after 1 week.
    What does bother is when I put my 16 month old NCR18650B in the ARE-C2+ and they came out 4.09,4.11,4.12v!! It has resting voltages of 4.16/17v With all my other chargers!
    I sent that charger back today for many reasons,,,,,,Primarily only charges at 1A! Also the inconsistencies of ending voltages w/ various batteries!
    Banned
    Aug 2013
    Valley Forge, Pa.
    What do you think? I have a few guesses!
    Battery: VTC6
    Chargers: Efest LUC V4 and Fenix ARE-C2
    Batteries had Identical voltages going in: 3.78v
    The battery in the EFEST was charged @ 2A. The battery in the Fenix was charged @ 1A.
    THE VTC6 IN THE FENIX WAS DONE 18 MINUTES EARLIER AND NOT SURPRISING CAME OUT @ 4.20V while the Efest came out @ 4.15v!
    Why do you think that is?
    I have Two [2] guesses!
    1.The Efest is not charging at a TRUE 2A
    2.The Final phase takes much longer on the Efest than the Fenix. I am almost certain this is the reason.This was not my only comparison, just the first w/ 2A VS 1A!
    HKJ REVIEWED THE EFEST AND THE THUNITE MCC4 WHICH SEEMS LIKE THE SAME CHARGER AS MY ARE-C2. HE WOULD KNOW!
    Banned
    Aug 2013
    Valley Forge, Pa.
    iirc didn't that get recalled?
    I know someone who had One and he had to send it back. Something about the plastic being too brittle and could not take the heat or cold!
    Flashaholic* ChrisGarrett's Avatar
    Feb 2012
    Miami, Florida
    I was probably the first one here with a VP2 and it was recalled. There was a problem with the plastic formula for the housing that if subjected to freezing temperatures, could cause the plastic to become brittle going forward. The little housing struts and spring stays, could break, although I never worried about that.
    My charger worked fine as it was, but I got the reformulated model after a month, IIRC.
    It's a great charger and extremely flexible, but it really doesn't do any analyzing, so it's just for charging. The three rates of 250/500/1A are right in the sweet spot for the cells I use and it does LiFePO4 3.2v cells and the 4.35v jobbies, so it's pretty future proof for a li-ion charger.
    Chris
    Chris
    Convoy: S2, S2+, M1, M2, Fenix: P1D, PD32, HL30, ET: D25C Ti, SF: 6P, ZL: SC-600, Klarus: P2A, Jetbeam: BA-20, Icon: Rogue 1, L3: L10, Xeno: E03, ShiningBeam: I-Mini, Olight: i3s, SWM: D40A, M11R, V11R, Maglite: 6Ds, MMs, Solitaires, LaCrosse BC-700, Maha C-9000, XTAR VP2, MP1S, XP1, MC1+, WP2 II, NiteCore i4, v2.
    Banned
    Aug 2013
    Valley Forge, Pa.
    I HAVE A CONFESSION!!! I AM NOT PERFECT,,,,,,ACTUALLY THAT IS NOT MY CONFESSION, BUT THIS IS!
    My Neighbor Jon Owns L.ionwholesale .com. He lives across the street and the warehouse is 1.5 miles away! Perrrrfect for a flashaholic!
    Ok,,,,I broke down from my norm[chargers that must charge to 4.20v],
    listened to HKJ's quote below regarding how I like/want chargers that charge like my Fenix ARE-C2[4.20V]
    "Look for chargers that do not terminate the charge or charge to 4.25 volt, they are basically the only ones giving full 4.20 volt.
    All chargers following the LiIon charge guidelines will give a lower voltage."
    ,,,,,,,,,,and realized I need to weigh ALL the options!
    My first Two chargers were Trustfire TR-003P4.Gives a FULL charge but takes 12/14 hours for a battery @ 3.60V! Of course my Fenix ARE-C2 will charge at that same voltage in ~ 2h!
    HERE IS THE CONFESSION!
    Being that Jon is a great guy, he gave me a PRE B'Day discount on the OPUS BT-3100 2.2 charger!!!!! So it has Six[6] out of the "SIMPLE SEVEN" PLUS many more features! ALL I have to do is ACCEPT that these newer chargers will NOT have a voltage of 4.20v OUT OF THE CHARGER WHEN TESTED ON MY DMM.
    The Voltage meter in the charger is consistent. ALL Four[4] slots "READ" 4.20V WHEN THE BATTERY IS DONE. All Four batteries measure 4.15V on my DMM.So it is 0.05v off. My K'power and Efest are about the same once the battery is charged. Depending on the age of the battery, the resting voltages will drop ~ 0.01v to 0.04v.
    Right now I am doing a "Discharge test" on my 4 X ORBTRONIC 18650 3400 mah batteries that I bought on 12.21.2012!! They have 427 cycles on them! I know the test is not perfect, my guess is it will have ~ 3000 to 3100mAh capacity.
    So now I have Eight[8] 4-Bay chargers!:
    3 X FENIX ARE-C2
    2 X T'FIRE-003P4[EMERGENCY CHARGERS]
    1 X EFEST LUC V4
    1 X NC I4[JUNK 2 BAYS ONLY WORK]
    1 X OPUS BT-C3100 2.2
    and,my CUTE K'Power L2.
    My ACTIVE chargers are 2 X Fenix ARE-C2, 1 x OPUS BT-C3100 2.2 AND MY K'POWER L2! They are on my MAIN desk in my Flashlight Laboratory.The others are in storage.
    PLEASE DO NOT BE TOO HARD ON ME!
    Keep in mind that with Lithium-ion batteries if you stop at a slightly lower voltage, for example 4.0 or even 4.1 they last much longer. There is a lot of published information on that phenomenon. One place to start is Battery University. Also, look at the discharge curve (the initial rapid voltage drop). There really is not much area under the curve from 4.2 down to to 4.1 or even 4.0. So you are putting a lot more stress on the battery and getting very little energy benefit in return.
    Banned
    Aug 2013
    Valley Forge, Pa.
    I did the Discharge test for my Orbtronic 18650 3400mAh batteries which I bought on 12.21.2012!! They have had 427 charge/discharge cycles ALL ON MY FENIX ARE-C2!!
    I understand what they are saying about charging at a lower voltage. These batteries are proof that they can last a long time w/ an "Off the charger" voltage via DMM of 4.20V!
    My guess as far as their capacity was pretty close,,,,they were even a little higher! Since it was discharged down to 3.0v and NOT 2.5v it would even be a little higher. Regardless, ~3100mAh and 4years 2months old w/ 427 cycles. They may have been charged to 4.20v BUT they were NEVER discharged[until now!] below 3.5V, Rarely under 3.6v and mostly 3.6V to 3.8v,,,,,,I believe that is a BIGGER key to their longevity than NOT charging them to 4.20v!
    Both have an effect on cell longevity. You are correct deep cycling decreases cell life. Tesla cycles within 85% of the total capacity in order to maximize battery life. The higher the voltage the greater the internal energy. We know that there are always harmful reactions occurring internally, and the higher the energy the more of them you get. You can also lower the internal chemical energy during storage by storing li-ion around 3.5v at lower temperatures. Lithium Ion (NCR) stored cold has demonstrated negligible loss even after 10 years.
    Feb 2012
    Miami, Florida
    Remember, some of us figure that the Opus BT-3100/3400s read a bit high. How high? I can't really say, but I figure that a 5% range (+/- a couple points) is probably justified.
    At what current did you discharge them at?
    Think about it and the sample size is small, but going by HKJ's testing new Panasonic NCR-Bs test out at about 3300mAh at 200mA and go down to about 3200mAh at a 1A discharge.
    http://lygte-info.dk/review/batterie...een)%20UK.html
    3300mAh when new isn't going to equate to 3300mAh after 427 cycles, regardless of how low you discharge them down to. I probably don't have 500 cycles on ALL of my NiMH and li-ions combined and if I do, it's not by much!
    10% off of 3300, due to cycles/age, is 330, so that puts you at 2970mAh, as just an educated guess. 5% of that number puts you back up around that 3150 range, where you find most of your cells.
    Extreme spread on that test is only 75 and your mean average is 3135.75, which is pretty close to the claimed 3400mAh and realized 3300mAh, after 400+ cycles.
    Numbers are fun.
    Chris
    Banned
    Aug 2013
    Valley Forge, Pa.
    ^^^ I discharged them at 1A
    I would never expect them to be the same mAh after 50 months/427 cycles! I think they are darn good batteries and it helps that I took care of them.
    iirc I did a run time test on MAX w/ my BST. Cumulative run time was ~50 minutes,,when they were new it was around 62 minutes,,,,Not bad at all!
    Numbers are fun,,,,,,I have charts w/ every battery and its charge/discharge cycles[how many]. I do this w/ batteries I never had before to see how long they last. Orbtronic was the first quality battery I got and they are still working!
    Banned
    Aug 2013
    Valley Forge, Pa.
    Thanks Chris,YEP,,,,,,,,,,I have several naked and BT NCR18650B.
    Of course when I bought those Orbtronics[ beginning of hobby b/4 CPF!] I did not realize they were re wraps and could be gotten cheaper!
    Banned
    Aug 2013
    Valley Forge, Pa.
    CLOSING IN ON 5K POSTS!
    MR. OPUS AND MR. FENIX ARE GOING TO GET ALONG FINE.IF I FIND IT NECESSARY TO HAVE A 4.20V CHARGE AFTER IT COMES OFF OF THE OPUS[4.15V], I WILL JUST PUT IT IN MY FENIX FOR 3 TO 5 MINUTES!
    Banned
    Apr 2011
    sydney aus
    Like Chris said the opus tends to read a little high but i think your ncr cells are holding up remarkably well considering the charge count.
    Only a 75 mah difference from highest to lowest on these four-impressive and shows how good these panasonic cells are.
    I agree with you that charging at 3.5v or there abouts probably has contributed to their longevity. I do the same and my oldest jetbeam 2300 cells which are almost 6 years old still show around 2000 mah.
    Actually i have never had a 18650 cell go bad yet over almost 6 yrs of use.
    Capolini i like how you give your lights and cells hard real world use which helps a lot of readers , 5000 posts thanks for your valuable contribution..
    Banned
    Aug 2013
    Valley Forge, Pa.
    Thank you swan!
    I am your average Joe when it comes to knowledge. I do like to give a lot of numbers and statistics so people have an idea of of how I use my cells and lights! I have always liked numbers! In 4th grade I was the Times table champion,REWARD: Get a drink of water[leave class] anytime I want!!
    Banned
    Aug 2013
    Valley Forge, Pa.
    I am going to post numerous discharge/capacity test results along the way.
    Posted like this: Battery/Purchase date/Cycles/mAh[capacity]
    With the exception of LGHG2/#1, All other batteries were discharged @ 3.0V and tested @ 1Amp
    VTC6 #1/8.22.2016/43CYCLES/3038mAh -HKJ GOT 2976mAh @ 1AMP
    VTC6 #2/8.22.2016/24 CYCLES/3047mAh
    LGHG2 #1/6.17.2015/151 CYCLES/2235mAh-This one was only discharged to 3.35V??
    LGHG2-#2/1.5.2016/58 CYCLES/3008mAh- ​HKJ GOT 2804 @ 1AMP.
    #2 LGHG2 works fine, not sure why it was only discharged @ 3.35v? It definitely affected the mAh but still seems low for .3V LESS of a discharge! I will test again.
    Nov 2011
    north carolina
    that opus is second to the mc3000
    its a great lil unit
    ive tried them all, and it was the best till i got the mc 3000
    you should get a mc3000
    its so much more flexible than anything out there right now
    beauty is you can set your cut off voltage to what ever you want
    ive got mine set at 4,23, and they will rest at 4.21 after an hour or so of coming off
    you can charge up to 3 amps , for ALL 4 CHANNELS if you need to, not just 1 amp
    youll find out how much fun battery charging can be if you get it
    Banned
    Aug 2013
    Valley Forge, Pa.
    Thanks for the suggestion. I just got this charger yesterday and I am ENJOYING it!
    I have too many to begin with!
    Banned
    Aug 2013
    Valley Forge, Pa.
    ENLOOP AAA 750mAH - HR-4UTBG-PURCHASED ON 11.25.2013-
    NOT SURE OF CHARGE CYCLES! USED IN 1 LIGHT AND 4 BATTERIES!
    AT THE MOMENT I have TWO AAA LIGHTS.I USE IMR 10440 IN MY ULTRATAC K18 SS.I USE THESE IN MY OLIGHT i3S-CU.
    That is impressive. 3.5 years old.Even if those are 75mAh off!
    Oct 2013
    USA
    [...] They may have been charged to 4.20v BUT they were NEVER discharged[until now!] below 3.5V, Rarely under 3.6v and mostly 3.6V to 3.8v,,,,,,I believe that is a BIGGER key to their longevity than NOT charging them to 4.20v!
    Not true. Doing all your discharges in the highest possible voltage range and unbalanced around 50% SOC is not good. In fact it is the worst possible management strategy when it comes to maximizing health (esp. cycle life). For example if instead you balanced your capacity use around 50% by using capacity only in the range 75%-25% (vs. 100%-50%) then studies show that you may gain close to 50% cycle life, e.g. you might get 600 equivalent full cycles instead of 400 cycles before your cells degrade to 80% of their original capacity. For details see my post here, esp. the final graph.
    Banned
    Aug 2013
    Valley Forge, Pa.
    Guess what Gauss163. I am not as technical as you!! I enjoy my hobby!
    According to you, for "having the worst possible management strategy" they sure have lasted long and are still doing well.
    80% of my lights are MODDED. When the batteries start getting weaker, for whatever reason, I am not worried about a few extra cycles,,,,,,,I just buy new batteries which are not that much these days!
    It is quite apparent that you like challenging people,,,even HKJ!
    I do not claim to have all this knowledge and am NOT interested in getting every spec out of a battery. I enjoy my hobby and am not going to let someone like you take the joy out of it!
    Jan 2015
    Ontario, Canada
    Quote Originally Posted by Gauss163 View Post
    Worst possible strategy or not, look at the life he has got out of the cells. Over 4 years and 400+ cycles and only around a 5% drop in capacity. This is what I was trying to tell you in the other thread Gauss. Imo it would be a waste of time and energy to try and use the 75-25% range even if it is "optimum". How much more life do you really need out of a $3 cell? For most users, I would suspect that the cells will die from old age before they could ever wear them out. These cells are very resilient and unless your hobby is playing with batteries or you have extreme OCD, there is no need to get fancy. Just charge them up fully, don't discharge them too low, store them anywhere in the 3.6-3.9V range and enjoy using your lights. Then, in 5 or ten years when they start getting tired, recycle them and grab a new batch of the latest cells.
