HDS Systems
Results 1 to 4 of 4
Thread: Batteries
    Unenlightened
    Mar 2017
    Default Batteries
    good day!
    help pls....
    -im considering to purchase nitecore mh27uv
    - can i use these batteries for my nitecore?
    18650 NL 189 3400mah
    or the new
    18650 NL 1835 (3.6v,12.6wh)
    18650 NL 1834 (3.7v, 12.6wh)
    is there any difference between these models of batteries?
    its in the nitecore website
    tnx
    Default Re: Batteries
    As far as I know, all of them should work acceptably. None of them are high drain batteries, but I think they should all be able to handle the requirements of your MH27UV.
    Aug 2015
    Singapore
    1834 is the same as the 189, model changed to probably reflect the cell size/capacity..
    1834-3400mah
    1835-3500mah
    specs say sub 4A draw...
    ::: space for rent :::
    A&Q Moderator
    Woods Walker's Avatar
    Jun 2008
    New England woods.
    Thread moved to here.
    The TK20. Yes it still rocks.
